'12 Ram question for the techs #1409941
03/27/13 09:13 PM
03/27/13 09:13 PM
central Florida
VL21 Offline OP
VL21  Offline OP
central Florida
I have a friend who asked me to ask you ... on a '12 Ram hemi ...
Has anyone run across a problem, persistent oil leakage, in the area of the oil filter, but only AFTER engine shutdown?
No apparent leak when running?
I can get more info probably, but it's not near me ...
My thoughts are it HAS to be running down from elsewhere, pooling somewhere and gravity at work after shutdown ...never seen the truck tho ...
It takes gasoline to interest me.
Re: '12 Ram question for the techs [Re: VL21] #1409942
03/27/13 11:39 PM
03/27/13 11:39 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
warranty. right to dealer.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: '12 Ram question for the techs [Re: VincentVega] #1409943
03/28/13 09:27 AM
03/28/13 09:27 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
For some odd reason there was a change-up in oil filter numbers after '07. Perhaps at one of the oil changes someone put the pre-'07 oil filter on there and it is causing the leak.
Not sure what differences are, could be the rubber seal and that would cause a leak.
Mo' Farts
Moderated by "tbagger".
Re: '12 Ram question for the techs [Re: Grizzly] #1409944
03/28/13 05:14 PM
03/28/13 05:14 PM
pennsylvania
poboyengineering Offline
pennsylvania
the oil filters in question will not interchange, they simply do not screw on if you have the wrong one.
if the leak is at the filter, try a new one. ive seen plenty of filters that leaked at the seam. also, overtightening the filter or debris on the seal will make them leak.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
