Re: small block pushrods
[Re: moparguy93]
#1409674
03/27/13 01:14 AM
03/27/13 01:14 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
well..what are you using for rocker arms?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Locomotion]
#1409679
03/28/13 10:23 AM
03/28/13 10:23 AM
Posts: 1,465 Carson City, NV
babarracuda
Carson City, NV
Have you checked the roller on the valve? With both my 1.5 and 1.6 rockers I had to get longer pushrods and shim up the shaft to get the proper geometry. If the roller does not stay in the center of the valve stem the geometry is off. The smallest problem will be the guides wearing very quickly. I used 5/16 .085 wall from Smiths. .595 lift 265@ .050 cam.
A shortcut is the fastest way to where you don't want to go!!!
[Re: moparguy93]
#1409681
03/28/13 12:45 PM
03/28/13 12:45 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I agree with the above - you spend ont he good stuff then skimp on one of the hardest stressed parts in the engine? Not good. I measure and order from Smith Bros. A high quality pushrod will go a long way to keeping the rest fo the valve train in shape. The wrong one will be "the weakest link".
