383 4spd question #1409004
03/26/13 03:07 AM
03/26/13 03:07 AM
Iowa
76dodgeboy Offline OP
Iowa
I had planned to put a 440 4spd in my Clubcab Powerwagon and I have a built 383 I had planned for my 80 D100. I purchased a aftermarket bellhousing and a Flywheel from a member. Can I use the flywheel on the 383 without any mods?
Re: 383 4spd question [Re: 76dodgeboy] #1409005
03/26/13 06:27 AM
03/26/13 06:27 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
as long as they are both neutral balanced
I am truckless..
Re: 383 4spd question [Re: 340SHORTY] #1409006
03/26/13 02:10 PM
03/26/13 02:10 PM
Iowa
Iowa
Weren't all Bigblocks that were mated to a 4spd? I've always heard 400/4spd were forged crank motors
Re: 383 4spd question [Re: 76dodgeboy] #1409007
03/26/13 04:33 PM
03/26/13 04:33 PM
scratchnfotraction Offline
383/400/440 cast crank use a 100 gram weight on the TC for external balance.IIRC
I used a 400 TC on my 440 cast crank no problems.
Re: 383 4spd question [Re: scratchnfotraction] #1409008
03/26/13 04:49 PM
03/26/13 04:49 PM
Iowa
Iowa
Aren't all 383s Forged cranks? I've never heard of a cast crank 383. My 440 I had planned to use is a steel crank. Using a NP435
Re: 383 4spd question [Re: 76dodgeboy] #1409009
03/26/13 05:42 PM
03/26/13 05:42 PM
I just know the 440 crank is cast. but 383/400/440 are external balance and can all use the 100gram weighted TC.
I aksed if I needed to keep the TC that was on the cast crank 440 with the replacment trans from a 400.
John Kunkle posted I was good to use the TC from the 400 with the big weight. and that 383/400/440 cast cranks share that 100 gram weight.IIRC
I used the 400 TC that came in the used replacment 727.
works fine
Re: 383 4spd question [Re: scratchnfotraction] #1409010
03/26/13 07:45 PM
03/26/13 07:45 PM
Iowa
Iowa
Im talking about Forged/steel Cranks. Ive Always heard 383s were forged steel cranks
Re: 383 4spd question [Re: 76dodgeboy] #1409011
03/26/13 08:25 PM
03/26/13 08:25 PM
dogdays Offline
dogdays  Offline
Such dangerous words, "I have heard".
There were 383s built with cast cranks, I would tend to put them in 1971. One can tell how an engine was built by looking at the engine ID pad. If there is a letter "E" stamped onto the pad the engine was built with a cast crank. Of course this doesn't include 1969 model year engines that have their engine code starting with "E383" or E440", because there the E is for 1969. But if your 383 has G383R____ E
on the engine ID pad it's a 71 model year engine that came with a cast crank.
Cast crank 383s, 400s and 440s all used the same external balance weight amount.
R.
Re: 383 4spd question [Re: dogdays] #1409012
03/26/13 11:29 PM
03/26/13 11:29 PM
Iowa
Iowa
My 383 is a steel crank. Its a mid 60s motor.
Again Im NOT talking about CAST crank motors
Re: 383 4spd question [Re: 76dodgeboy] #1409013
03/26/13 11:35 PM
03/26/13 11:35 PM
Iowa
Iowa
All "I've Heard" has been on this site and no other.
Re: 383 4spd question [Re: 76dodgeboy] #1409014
03/27/13 02:19 AM
03/27/13 02:19 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Every 400 I've ever seen was a cast crank
Re: 383 4spd question [Re: BulletBob] #1409015
03/27/13 03:57 AM
03/27/13 03:57 AM
Iowa
Iowa
Been told trucks with 400/4spd was forged
