Spindle article in March '05 Mopar Muscle
#14087
01/19/05 11:49 AM
01/19/05 11:49 AM
Posts: 16,810 Between Houston & Galveston TX
SattyNoCar
Anyone see it yet? Opinions? Someone has finally taken the time to compare the taller later B-body spindle to the popular A-body piece used in brake upgrades. They mapped out the geometry changes through out the suspensions travel, looked for binding at full travel, etc, etc. They found a few concerns, but for the most part debunked most of the myths floating around. I won't go into great detail here, that's what the article is for, I'll just say that (as some here have said) the later B spindle will work fine despite being taller. Hmmm....maybe now's the time I put my extra spindles on ebay?
John
Re: Spindle article in March '05 Mopar Muscle
[Re: SattyNoCar]
#14088
01/19/05 12:00 PM
01/19/05 12:00 PM
Somebody did that years ago.
Mostly those of us running them for years.
But now since it's in print it must be gospel, except to those that have an ideological axe to grind against MM or tall spindles.
Thor
[Re: SattyNoCar]
#14092
01/19/05 02:25 PM
01/19/05 02:25 PM
Ahhh, the Dulcich vs. E-booger (Mopar Muscle vs. Mopar Action) war over spindles continues.
[Re: SattyNoCar]
#14093
01/19/05 02:26 PM
01/19/05 02:26 PM
Got search?
Been pointed out on this very site for a long time and links provided.
Thor
[Re: SattyNoCar]
#14094
01/19/05 02:26 PM
01/19/05 02:26 PM
Posts: 11,076 Berlin, N.J.
abodyjoe
Berlin, N.J.
bill reilly from www.bigblockdart.com wrote that... i'm sure if anyone wanted more info about it he would be happy to answer the questions....
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#14095
01/19/05 02:28 PM
01/19/05 02:28 PM
abodyjoe
Berlin, N.J.
[Re: Michael]
#14098
01/19/05 03:06 PM
01/19/05 03:06 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I was concerned about the raised roll center also.
Suppose you are in a drag car, with no sway bar and loose shocks and suspension. You hit a greasy spot at half track and get a little sideways. Will that higher roll center hinder your recovery? Will it cause the car to gyrate back and forth until you lose it? Or is it no big deal, won't make any big difference?
BTW, does any one know if software like they used can be downloaded free anywhere?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#14099
01/19/05 03:08 PM
01/19/05 03:08 PM
abodyjoe
Berlin, N.J.
if you guys have questions just go to the forums on www.bigblockdart.com and ask bill himself.....
[Re: dezduster]
#14101
01/19/05 05:22 PM
01/19/05 05:22 PM
taller spindles LOWER the roll center, assuming no other changes.
Thor
[Re: HemiDave]
#14104
01/19/05 08:29 PM
01/19/05 08:29 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I ran "F" body spindles on my 64 Polara for about 5 years without incident. Because of the controversy on this site and in the various magazines, when I rebuilt the front suspension, I switched to "A" body spindles. Personally, I could tell no difference in handleing that I could contribute to the spindles. I don't race it, but I do drive it fast and hard. Go with what you are comfortable with.
This would be so much easier if I knew what I was doing...
[Re: FuryUs]
#14106
01/19/05 09:26 PM
01/19/05 09:26 PM
e-mail me that article sat 73 , you been crying about being broke , then hit that job , hell you got more money then me now ,cause i can't afford the magizine. But i need to upgrade my 68 RR, with discs, don't want to pay too much you know. jai@koyote.com
[Re: SattyNoCar]
#14109
01/20/05 12:20 AM
01/20/05 12:20 AM
Posts: 4,323 NY NY
340duster340
NY NY
i am sure the taller spindles will work, but i preferr to stick with what the car was designed for. the engineer that designed the suspension probabley forgot more than most of us know and who knows what additionl stress may be added to the front structure of the car from the taller arm.
besides, i have a few sets and they are impossible to sell. everyone wants the a body spindles.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#14110
01/20/05 12:30 AM
01/20/05 12:30 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Once again, all somebody needs to do is make a revised upper control arm, very, very, VERY similar to the tubular and adjustable versions out there that compensates for the change in geometry and puts things back to stock specs. Not only will they make a profit and sell a whole bunch of them, and not only will we all be able to enjoy the splendor of $15 spindles from the pick-a-part, everyone will be happy and this will never be a point of argument again.
[Re: DoctorDiff]
#14112
01/20/05 12:46 AM
01/20/05 12:46 AM
Montclaire
Scranton, PA
Firm Feel already makes that revised upper control arm.
Then they should start advertising it. Is it just adjustable, or purpose-made?
[Re: farmboy70]
#14115
01/20/05 01:04 AM
01/20/05 01:04 AM
Montclaire
Scranton, PA
Actually, both of you guys are somewhat incorrect. First, both advertise in Mopar Action, and I could find neither company advertised in recent issues of muscle. Second, while they do offer adjustable upper arms and will take custom orders, I'm talking about a bolt-in, ready to go UCA that requires absolutely no thinking. "Install this upper arm on your (fill in the blank) mopar with the tall spindles and you will have the same geometry as if you used your stock or 73-76 a-body pieces." That's what they need to market, and they might even already make it. But that kind of advertising is what's going to sell parts. Then everyone wins.
[Re: DoctorDiff]
#14116
01/20/05 01:06 AM
01/20/05 01:06 AM
Montclaire
Scranton, PA
The Firm Feel UCA is available for taller knuckles. Firm Feel advertises they can build them to your specs.
If they do, they're awful shy about it.
[Re: SattyNoCar]
#14120
01/20/05 09:36 AM
01/20/05 09:36 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Thor
Great response. Is there an article out there already that mapped out the diffrences between the two spindles? Yes, a lot of people have said they used them with no problems, but has anyone before taken the time to prove they can be used without problem?
Funny how for all the bashing this subject gets, this post has gotten only two replies so far. Maybe time for a subject line change?
the article was written by Bill Reilley (sp) who does the alterKtion and I thought ran the Big Block Dart site...he knows his suspension stuff, there's a lot of good info in it, and thorough analysis. I'd trust it...
[Re: Montclaire]
#14121
01/20/05 09:48 AM
01/20/05 09:48 AM
patrick
Grand Haven, MI
Uhh, the guys over at firm feel already do.
[Re: patrick]
#14122
01/20/05 11:18 AM
01/20/05 11:18 AM
SattyNoCar
Glad to see some responses!
As for the article having been known over at bigblockdart.com, why hasn't anyone mentioned it before? I can't say I've read ALL the spindle threads here, but the ones I read, there was never any mention of someone having proved the tall spindles will work. Its always turned into a pissing match with a bunch of guys just saying stuff like 'I've used them on my car for years'.
John
[Re: SattyNoCar]
#14123
01/20/05 11:25 AM
01/20/05 11:25 AM
Posts: 12,120 City of Champions
Prostock
City of Champions
What more proof could someone want?
[Re: SattyNoCar]
#14126
01/20/05 12:37 PM
01/20/05 12:37 PM
Then you obviously have NOT read ALL the spindle threads because bigblockdart.com's artical has been mentioned repeatedly, sometimes even by Bill himself who has weighed in on the subject on occasion.
Someone want to explain to my how any UCA redesign that still uses the stock pivot locations is gonna do anything other than lighten your wallet? Cause it ain;t gonna change the roll center unless I am forgetting something.
Thor
[Re: Montclaire]
#14129
01/20/05 10:55 PM
01/20/05 10:55 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
.... I'm talking about a bolt-in, ready to go UCA that requires absolutely no thinking. "Install this upper arm on your (fill in the blank) mopar with the tall spindles and you will have the same geometry as if you used your stock or 73-76 a-body pieces." That's what they need to market, and they might even already make it. But that kind of advertising is what's going to sell parts. Then everyone wins.
That will not exist because an A-arm change ALONE will not do that.
The complete absolute infinitissimal 3-D geometry through it full range of motions will not have every geometrical result absolutely mirrored with a taller A-arm even if everything else is changed.
BUT changes can be made to make the handling and overall resulting behavior the same. Because there are so many input varibles in suspension design, there are many different paths to take to get to the same place.
[Re: SattyNoCar]
#14130
01/20/05 10:56 PM
01/20/05 10:56 PM
autoxcuda
So Cal
The guy TAcare?? from Colorado plotted this out and posted it here more than once. Bill Reily spend the time to measure a car and put the numbers in an impressive computer display. People that have experience in suspension design understand the small height change is not a big deal and will bring a slight camber gain. Why spend 15-30 hours of effort to prove a web arguement? Quote:
[Re: DoctorDiff]
#14131
01/20/05 11:01 PM
01/20/05 11:01 PM
The UCA is redesigned so the upper ball joint is plumb when used with taller knuckles.
I don't think I understand this. Unless you mean that the UCA ia a touch longer than stock so that the ball joint won't "overangle" as claimed by Ebooger. Of course no one has proven that to be a problem and I believe Dulcich did a little research into ball joint angles and pretty much concluded that wasn't an issue.
Thor
[Re: DoctorDiff]
#14132
01/20/05 11:03 PM
01/20/05 11:03 PM
autoxcuda
So Cal
you mean the UCA ball joint socket is tilted slightly. So the range of angles the ball joint at factory suspension height is not changed.
But this is not absolutely necessary in reality. But if you were making an new A-arm you should include it and that's why Dick added it. It's a nice to have, but not a must have.
Those UBA ball joint can take a lot of angle. Most every circle track car runs very large angles on those very same K772 ball joints.
#14133
01/20/05 11:08 PM
01/20/05 11:08 PM
Montclaire
Scranton, PA
Let's just be honest here. What you meant to say was, "some homeless dude wrote it down on a napkin and gave it to Dulcich, who then just reprinted it verbatim in MM without reading it." I'm not saying it's incorrect information. I'm just saying that I doubt Dulcich concluded anything.
[Re: AndyF]
#14135
01/21/05 03:17 AM
01/21/05 03:17 AM
Correct. Dick tweaked the boss for the upper ball joint a tad when he designed these arms so that they duplicate the static ball joint angle at some presumed ride height. (probably a tad lower than stock if I know the way that Dick thinks)
It doesn't make the geometry the same as stock since the taller knuckle alters that, it is designed to keep the ball joint in a narrower window of angle travel.
would i be correct in assuming that these 'new' arms would 'be off' a little bit on A body spindles?
[Re: 71charger]
#14138
01/21/05 06:00 PM
01/21/05 06:00 PM
Pauls69
super gas
super gas
i read the bigblock.com article & it was very refreshing to read some actual tests vs old wives tales. although parts of the article were a little out of my depth, the point was it's ok to run later model disk brakes ("B") on our old mopes. what's more dangerous, some nuances that most drivers won't notice, or someone tooling around with 4 wheel drum brakes having to make a panic stop? good work bigblockdart & MM!
[Re: Montclaire]
#14141
01/25/05 10:03 AM
01/25/05 10:03 AM
I said exactly what I meant to say. If you got issues use your own words and don't drag me into your problems.
You are one of the people I was referring to with the ideological axe to grind. Your information is less than useful and not based on any FACTS.
So go stroke your ego elsewhere and keep me out of it.
Thor
