#14074 - 01/18/05 06:33 PM SB Kick down linkage
The 340 in my 70 duster will soon be having an Edelbrock performer manifold with a 1" spacer atop. The kickdown linkage rod will be too short. Will the rod from a big block be longer and shaped well enough to work?
#14075 - 01/18/05 07:17 PM Re: SB Kick down linkage
MoparforLife Offline
Loc: Upper Midwest
first I will ask you why you would use the performer over the stock intake. About the only advantage you will get is it is lighter. From what I have seen the performance won't be much better. You will have to lengthen (splice in) the rod from the carb to the belcrank and rebend to get the right angle for your spacing to get the proper adjustment. Remember to use the light spring to pull it into constant contact with the carb. pin.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
#14076 - 01/19/05 12:47 AM Re: SB Kick down linkage [Re: MoparforLife]
bigD Offline
Loc: American canyon ,ca
Ditto on the mods to the rods /likange,D.
2008 Charger R/T R&T,1999 Dakota R/T,1998 Durango SLT 4x4,1969 Dart GT vert-under construction,1968 Charger R/T.
#14077 - 01/19/05 08:23 AM Re: SB Kick down linkage [Re: bigD]
stumpy Online   content
Loc: Grand Prairie,Texas
The hardware stores carry a hollow nut about 2" long that screws on the existing linkage then you buy a piece of all- thread the right size and cut to fit and install the sloted piece of linkage that attaches to the carb on the end of the all-thread. The nut will give some adjustability for finite tweeks.
#14078 - 01/19/05 08:42 AM Re: SB Kick down linkage [Re: stumpy]
Why the performer intake? Well, I believed the ad in the mopar car mags back 8 years ago or so when Edelbrock was showing significant increases in hp and torque when the performer intake and carb were teamed together. As to whether it helped, that's anybody's guess. Bouchillon makes a kickdown linkage system, but it's megabucks and I'm hoping to find a cheaper way. Thanks for the tips. I may just weld a 2" piece of rod steel in the middle. I was even thinking of cutting the rod in half, then slipping a hollow steel rod over the break, adjusting it to the correct length, then crimping it. That way I could always restore it to its original length. I was just hoping that perchance the BB rod was sufficient. Guess it's not.
#14079 - 01/19/05 12:20 PM Re: SB Kick down linkage
This is what I used on my 360 van. It cost $2.45 and 20 minutes work.
1428459-kick down.jpg (125 downloads)
#14080 - 01/19/05 01:16 PM Re: SB Kick down linkage [Re: stumpy]
YOu gotta realize most car ads, even in mopar specific magazine, use SBC test data.
While I am not familar with the specific ad you are talking about it's possible this is the case.
I remember an ad for one of the aftermarket SBC heads that compared their head on a 350 versus a stock 305 head on a 350.
Hmm, let's put a small head on an engine that it never came with then show big gains. Yeah, that'll get the suckers.
You gotta take ads with a big old grain of salt.
Thor
#14081 - 01/19/05 01:32 PM Re: SB Kick down linkage
Hotwheelsjr Offline
Loc: Surface of the Sun, AZ
Thor
Huh?? What does this have to do with kickdown linkage?
#14082 - 01/19/05 02:02 PM Re: SB Kick down linkage
dart4forte Offline
Loc: Mesa, Arizona
I'm running an Airgap on my 360. All i did was weld a 1" extension on the rod coming up from the bell crank and made adjsutemnts from there.
#14083 - 01/19/05 02:09 PM Re: SB Kick down linkage [Re: dart4forte]
"Huh?? What does this have to do with kickdown linkage?"
It has to do with the original post about why the change was necessary.
Edited by stumpy (01/19/05 02:12 PM)
#14084 - 01/19/05 02:21 PM Re: SB Kick down linkage [Re: stumpy]
Hotwheelsjr Offline
Ahhhhh, okay. I see the point. My bad, carry on.
#14085 - 01/19/05 02:34 PM Re: SB Kick down linkage [Re: Hotwheelsjr]
Okey Dokey.
#14086 - 01/19/05 08:15 PM Re: SB Kick down linkage [Re: stumpy]
Yeah, I can see how easy it is to modify the linkage rod that goes to the carb. But specifically I was asking about the rod that comes up from the tranny to the bell crank which will have to be mounted on an extended height bracket. Doesn't that one have to be lengthened and will a BB rod work? Heck, maybe I only need to lengthen and reshape the carb rod and the bell crank takes up the difference in height for the tranny rod. Sorry to ramble on with this thread but I'm eager to fire her up and this is the last hurdle.
25,338 Registered Members
190,107 Topics
Happy Father’s Day
by humpty
06/17/18 11:26 PM
carlisle room?
by pettyblue440
06/17/18 10:42 PM
Too much carb ?
by ozymaxwedge
06/17/18 10:23 PM
68 a-body convert a-pillar trim
by njmopar
06/17/18 10:17 PM
