2nd time bleeding brakes?? #1407228
03/23/13 05:51 PM
03/23/13 05:51 PM
abc440 Offline OP
abc440  Offline OP
I installed front disc brake conversion last week. Bled brakes, took for test run. Stop ok slow, but no lock up at 40 mph. I read on here about gravity bleeding. Jacked up rear end and opened RR bleed screw 1 turn, been setting for 1 hour, not 1 drop out yet (top off master). On 71 charger, any ideas???? Thanks dave (also new master c)
Re: 2nd time bleeding brakes?? [Re: abc440] #1407229
03/23/13 06:11 PM
03/23/13 06:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why jack it up? Just open the bleeders until fluid runs out. You may not have opened them far enough.I have pulled bleeders out completely because they were plugged.
Re: 2nd time bleeding brakes?? [Re: stumpy] #1407230
03/23/13 08:35 PM
03/23/13 08:35 PM
abc440 Offline OP
abc440  Offline OP
I took rear wheel off just to get a better view and see what i was doing. Took bleeder screw all way out, not stopped up. It has been 3 hours, still no fluid. Have you used the one man bleed kit before from parts store? Do they work?
Re: 2nd time bleeding brakes?? [Re: abc440] #1407231
03/23/13 08:45 PM
03/23/13 08:45 PM
If they dont pump up then they are bled out tho there could be a slight amt of air in there that is hindering things but to K.I.S.S. it sounds like there ain't enough braking force at the wheels for whatever reason as it for sure should lock em up. would they lock up before the swap? What M/C What discs? Could get all 4 wheels off of the ground & idle it in gear & have a helper hit the pedal to see what the rears do and spin the fronts forward by hand & same thing. If air I'd bleed the M/C then rr/lr/rf/lf. On gravity bleeding sometimes you have to push the pedal a bit to get the flow started & doing both is the best.
Re: 2nd time bleeding brakes?? [Re: RapidRobert] #1407232
03/23/13 08:55 PM
03/23/13 08:55 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
proportioning valve.you will probably need a vacuum bleeder for rear
Re: 2nd time bleeding brakes?? [Re: d-150] #1407233
03/23/13 10:03 PM
03/23/13 10:03 PM
IN
ahy Offline
ahy  Offline
IN
If you want to jack it, suggest you do both ends. With the rear higher than the front, gravity bled may not work so well.
Re: 2nd time bleeding brakes?? [Re: d-150] #1407234
03/23/13 10:16 PM
03/23/13 10:16 PM
abc440 Offline OP
abc440  Offline OP
Yes, I put portioning valve in the line going to rear. I jacked up rear just an inch to get rear wheels off. Thaanks
Re: 2nd time bleeding brakes?? [Re: abc440] #1407235
03/23/13 10:22 PM
03/23/13 10:22 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
what happens is there is a valve in their that goes off center and will cut off fluid to front or rear if it thinks there is a leak in the system.if you pull vacuum with bleeder tool the valve will center and let fluid in line
Re: 2nd time bleeding brakes?? [Re: d-150] #1407236
03/24/13 10:51 PM
03/24/13 10:51 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Gravity bleed..you need to raise the front higher than the rear..when bleeding the rear..and reverse for the front..works pretty good..
Phoenix injector [Re: AARCONV] #1407237
03/25/13 12:46 PM
03/25/13 12:46 PM
central,pa
P
ply64post Offline
ply64post  Offline
P
central,pa
This makes the job very easy and less of a mess.It can be used to bleed brakes and hydraulic clutches.You push the fluid from the bleeder up to master cylinder which all the air is pushed out.Have one of my own and works perfectly.No fluid running over your detailed parts.If you do your own brake and hydraulic clutch work it is a must You won't be sorry it saves a lot of headaches!!!
http://www.gwrauto.com/phoenix/phxinj.html
or Google Phoenix injector
Re: Phoenix injector [Re: ply64post] #1407238
03/25/13 04:32 PM
03/25/13 04:32 PM
P
Paul_Fancsali Offline
P
Just used a Lyle bleeder on all 4 wheels yesterday worked great small cup and lid with tube threw it plus small amount of fluid in it and pump the brakes with bleeder open Cheap and can be made with a jar with two holes and vinyl hose.
Re: 2nd time bleeding brakes?? [Re: abc440] #1407239
03/25/13 09:36 PM
03/25/13 09:36 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
any ideas????
Yeah, bleed em the right way...
Try depressing the pedal about an inch and hold it there with a stick. May do the trick.
Re: 2nd time bleeding brakes?? [Re: abc440] #1407240
03/26/13 12:25 AM
03/26/13 12:25 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
They work fine.
I want my fair share
