Re: 440 head bolt leaking coolant [Re: JohnRR] #1406402
03/24/13 09:42 AM
03/24/13 09:42 AM
wisconsin usa
moretork03 Offline OP
wisconsin usa
under the valve cover
Re: 440 head bolt leaking coolant [Re: moretork03] #1406403
03/24/13 11:38 AM
03/24/13 11:38 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Its past tomorrow , did you pull the bolt and find coolant in the hole ? Put the pressure tester on without the bolt and look for the leak ?
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406404
03/24/13 01:20 PM
03/24/13 01:20 PM
wisconsin usa
wisconsin usa
got to go on the road for work for a week or two so will be on it when I get back, I will chime back in on what I find out and thanks for the help!
Re: 440 head bolt leaking coolant [Re: moretork03] #1406405
04/04/13 07:01 PM
04/04/13 07:01 PM
wisconsin usa
wisconsin usa
well, coolant was definitely coming thru bolt hole on pressure test, sealed with permatex #2 just like the haynes manual says and leak is gone. not sure of the whys or why nots but
Re: 440 head bolt leaking coolant [Re: moretork03] #1406406
04/05/13 11:27 AM
04/05/13 11:27 AM
U.S.S.A.
U.S.S.A.
Good that you got the leak stopped.
Hopefully the bigger issue of WHY there is coolant coming up that hole doesn't get worse.
then there is the torque aspect, I don't know how the torque value of the bolt is changed by the use of permatex vs. oil.
But as long as your happy with the result I guess that is all that really matters :
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406407
04/05/13 11:33 AM
04/05/13 11:33 AM
I wish you the best but I ain't holding my breath
Re: 440 head bolt leaking coolant [Re: RapidRobert] #1406408
04/05/13 01:11 PM
04/05/13 01:11 PM
dogdays Offline
dogdays  Offline
Welcome to the Optimist's Club!
R.
Re: 440 head bolt leaking coolant [Re: dogdays] #1406409
04/05/13 04:44 PM
04/05/13 04:44 PM
U.S.S.A.
U.S.S.A.
R.
I'm trying
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406410
04/06/13 12:14 AM
04/06/13 12:14 AM
wisconsin usa
wisconsin usa
well, ran it pretty hard today = 6800 rpm and still not leaking.guess I"ll find out for sure at the track come the end of may
