Widest rims possible on 1973 Dodge Charger #1405876
03/21/13 03:00 AM
03/21/13 03:00 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
What's the widest rim sizes possible on a 1973 Dodge Charger? For the rear, I like the looks of 295/50R15 on 15 inch by 10 inch rims is this possible without modification? or would it require something like Dr diff offset hangers? how wide can I go on the front? Also I like the look of the rear being slightly higher than the front, not by a lot though.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Widest rims possible on 1973 Dodge Charger [Re: xyxxjx] #1405877
03/21/13 03:09 AM
03/21/13 03:09 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You can safely fit a 10" wide rim in the rear with 4 3/4" backspacing as long as the leaf springs aren't wasted and sagging. Up front, a 9" rim fits with the same 4 3/4" B.S.
Re: Widest rims possible on 1973 Dodge Charger [Re: Kern Dog] #1405878
03/21/13 03:28 AM
03/21/13 03:28 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
good to hear, I was almost certain I had to do modifications to fit 295s on 10 inch rims in the rear.when you say sagging leaf springs, do you mean if they're flat and have no arch left?
Re: Widest rims possible on 1973 Dodge Charger [Re: xyxxjx] #1405879
03/21/13 03:32 AM
03/21/13 03:32 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Yeah... They should be at least 5 leafs in each pack and have some degree of arch. Depending on the tire, you may need to roll the inside edge of the metal of the wheelwells to avoid contact. I'd also avoid giving rides to any robust people. When you run tires this wide, you have to make sacrafices....
Re: Widest rims possible on 1973 Dodge Charger [Re: Kern Dog] #1405880
03/21/13 03:44 AM
03/21/13 03:44 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
got it no fat chicks
you mean something like this?https://www.youtube.com/watch?v=3v_KdONArm0&feature=youtube_gdata_player
