340 O heads , what engine did they come on ??. #140533
10/23/08 07:42 PM
10/23/08 07:42 PM
Ont Canada.
Hardcharger65 Offline OP
Ont Canada.
Id like to find out what year 340 engine O heads came on pn # 3418915 B, anyone have a clue ??, thanks Moparts.
Re: 340 O heads , what engine did they come on ??. [Re: Hardcharger65] #140534
10/23/08 07:52 PM
10/23/08 07:52 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Those are the same as a J head.
Be the same years of production as a 915 J head, 1970-72
Re: 340 O heads , what engine did they come on ??. [Re: RobX4406] #140535
10/23/08 08:00 PM
10/23/08 08:00 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
And, U and X, and whatever other letters may be on there.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: 340 O heads , what engine did they come on ??. [Re: 340727dart] #140536
10/23/08 08:24 PM
10/23/08 08:24 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
X's are a different casting number than the O,J,U 915 castings.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 340 O heads , what engine did they come on ??. [Re: CJK440] #140537
10/24/08 08:46 AM
10/24/08 08:46 AM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
Do the '73 340 heads have any letter designation?
Re: 340 O heads , what engine did they come on ??. [Re: Seth_Jones] #140538
10/24/08 08:51 AM
10/24/08 08:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Letter designation don't mean anything. Not even the J.
Re: 340 O heads , what engine did they come on ??. [Re: MoparforLife] #140539
10/24/08 10:41 AM
10/24/08 10:41 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Ive been told the X head is a better flowing head. It was built for the 2.02 intake, where as the rest of the heads were built with the 1.88 intake and they added the 2.02 later.
Again, this is what I was told by a very knowledgable friend of mine, just passing it on to you guys. If I'm wrong, or someone THINKS Im wrong - don't string me up for it!!
Re: 340 O heads , what engine did they come on ??. [Re: wkroncke17] #140540
10/24/08 10:52 AM
10/24/08 10:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There is allot of misinformation about early small block castings due to the various letters cast into them, it seems that people have a tendancy to believe that one letter or another offers something special....They didn't.
As mentioned, all 915 heads were the same castings regardless of the letter cast into them (BTW there were some with no letters at all). The "X" heads were a different casting number (ended in 894) but even those are nearly identical to 915 head castings, there's been allot of tests stacking one against the other, niether has ever been proven to be significantly better than the other (individual casting and valve job variables could easly erase any advantage by either).
If you want to buy a set of good early iron small block heads pick any of the above and go to a good machine shop, the end results will be the same no matter which cores they start with. If you want more bolt on HP simply buy a set of late model 308 castings, much better flowing head than any early head in stock form.
Re: 340 O heads , what engine did they come on ??. [Re: ScottSmith_Harms] #140541
10/24/08 11:44 AM
10/24/08 11:44 AM
beentheredonethat
AverageJoe Offline
AverageJoe  Offline
beentheredonethat
I'm looking at buying a Dart - it has a 70 340 in it but has one X head and one U head - whassup with that and is it an issue ?
Re: 340 O heads , what engine did they come on ??. [Re: AverageJoe] #140542
10/24/08 12:29 PM
10/24/08 12:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Averagejoe,
Totally normal, the factory used what they had, many cars got two different letters, further evidence that there was no difference between them.
Re: 340 O heads , what engine did they come on ??. [Re: AverageJoe] #140543
10/24/08 12:55 PM
10/24/08 12:55 PM
RobX4406 Offline
RobX4406  Offline
Same here, got a 70 car with an X and an O head.
Re: 340 O heads , what engine did they come on ??. [Re: RobX4406] #140544
10/24/08 01:18 PM
10/24/08 01:18 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Thats the "hugs and kisses" 340.
Re: 340 O heads , what engine did they come on ??. [Re: CJK440] #140545
10/24/08 01:32 PM
10/24/08 01:32 PM
RobX4406 Offline
RobX4406  Offline
Car hugged my cash as I kissed it goodbye!
Re: 340 O heads , what engine did they come on ??. [Re: CJK440] #140546
10/24/08 01:40 PM
10/24/08 01:40 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I like that.
BTW, I had a 30K mi unrestored 70 340 duster with an O and U (Only this missing was the I).
It went to MI and the guy put two X's on it when he restored it.
Re: 340 O heads , what engine did they come on ??. [Re: CJK440] #140547
10/24/08 01:44 PM
10/24/08 01:44 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Those came on pink cars and hit dealers lots in time for valentines day.
OK, I'm done
Re: 340 O heads , what engine did they come on ??. [Re: Rapid340] #140548
10/25/08 03:42 AM
10/25/08 03:42 AM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
Plenty 340s down under had 'Z' heads as well, so why is it 'J' heads get all the glory when as mentioned earlier that most of the heads are all the same.
Re: 340 O heads , what engine did they come on ??. [Re: RobX4406] #140549
10/25/08 08:18 AM
10/25/08 08:18 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Ditto -- the 340 in my Demon has one X and one Z head. Both are 2.02/1.60 and were hogged out at the same time, so I have no reason to believe they didn't originally come from the same engine. In speaking with az_a12_bee, a friend of his bought a 70 340 Dart from the same guy I bought my heads from and he has indicated the numbers matching block in his Dart has different lettered heads also -- we assumed the previous owner may have had the two sets of heads off the original motors at one time and some how mix and matched them when they went back on the motors -- only diff is, the pair I have has had extensive port work and the pair he has are still stock. The original owner had physical control over all 4 heads until we bought our respective pairs. His came installed on his #s matching block and the pair I bought were not installed on anything at the time. Who knows...
Re: 340 O heads , what engine did they come on ??. [Re: ScottSmith_Harms] #140550
10/26/08 03:06 PM
10/26/08 03:06 PM
North Florida
RebelDart Offline
super street
RebelDart  Offline
super street
North Florida
Someone told me the U heads were six-pack heads ? Were 340 six-pack heads different ?
Re: 340 O heads , what engine did they come on ??. [Re: RebelDart] #140551
10/26/08 03:17 PM
10/26/08 03:17 PM
RobX4406 Offline
RobX4406  Offline
6 pack heads were different in that they had a different pushrod hole location.
I have a pair of U heads that are not 6 pack heads, standard pushrod location.
Re: 340 O heads , what engine did they come on ??. [Re: RebelDart] #140552
10/26/08 03:46 PM
10/26/08 03:46 PM
Upper Midwest
Upper Midwest
Yes 6 pack heads are different but the letter don't have anything to do with it.
