Re: Dana 60 8 lug to a 5x5.5
[Re: 340SHORTY]
#1404989
03/22/13 02:09 AM
03/22/13 02:09 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have in my garage at this moment a Dana 60-2 rear that is factory equipped with 5 lug axles with a 5 on 5.5" bolt circle. The axle tubes are 2.785" in diameter rather than the more common 3" or 3.125". This unit is equipped with a PowerLOck carrier and 4.10 gears. The OEM use was in the Jeep Gladiator pickups from the early 60's. This not a floating axle unit, it is just like a car but with 12" brake drums and requires 16" wheels. I had plans to use it in my Ramcharger build, but used a 3/4 ton truck housing. This needs to find its way back to a Jeep
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1404990
03/22/13 02:24 AM
03/22/13 02:24 AM
Posts: 26 US
BBD150
US
if you werent across the country id be interested in that.
i plan on looking into a way to do a budget disc brake conversion next. ive seen some guys run honda disc brakes but i cant imagine that being very cheap.
[Re: BBD150]
#1404991
03/22/13 08:28 PM
03/22/13 08:28 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I know that on ford 9" truck rears, you can use front bronco rotors 79ish? and brackets from speedway motors for gm metric calipers. The late 80s front wheel drive caddy rear calipers bolt to the brackets. They have a cable parking brake. Since you are using a 5 1/2 bolt pattern it may work.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
