Re: Dana 60 8 lug to a 5x5.5
[Re: RUNCHARGER]
#1404975
03/20/13 10:31 PM
03/20/13 10:31 PM
Posts: 26 US
BBD150
US
If you're not in a rush and have old trucks in junkyards near you, there were Dana 60's installed in 60's F100's with the 5 on 5.5 pattern. I narrowed one of those for my 64 a few years ago, but it would be near a bolt in for your app.
Sheldon
ive been looking for dana 60 5 lug factory axles. i read that they were put in ram chargers in the early 90s in one of the special packages. were they ever put in the 94 and later trucks?
i also read that its usually cheaper to have a machine shop do the work changing the lug on the 60. is there any companies in the Indiana Ohio or Kentucky area that are good?
[Re: BBD150]
#1404976
03/20/13 11:28 PM
03/20/13 11:28 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Measure the width of the axle. Being a dual rear, it may require some tubbing of the fenders to fit.
They will often be narrower than a standard truck dual rear, like a cab & chassis truck
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: BBD150]
#1404977
03/21/13 12:03 AM
03/21/13 12:03 AM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Wrong on both. No 60 rear 5 lug.
[Re: hp383]
#1404980
03/21/13 03:16 AM
03/21/13 03:16 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The 80s B250 my friend had was a 9 1/4.
I am truckless..
[Re: 340SHORTY]
#1404981
03/21/13 09:49 AM
03/21/13 09:49 AM
Posts: 2,683 Des Moines IA
Soopernaut
Des Moines IA
International used a 5 on 5.5 bolt pattern Dana 60 on some trucks and Travelalls.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: hp383]
#1404983
03/21/13 08:19 PM
03/21/13 08:19 PM
Posts: 26 US
BBD150
US
yea i plan on tubbing the bed anyway to fit some wider tires so thats not really an issue.
im trying to decide if i want to convert the d60 or just stick with 8 1/4 or 9 1/4 rear ends.
