How long can I leave it plugged in #1404827
03/19/13 01:17 PM
03/19/13 01:17 PM
cumminsexpress99 Offline OP
99 Dodge CTD, How many hours before I start the truck can I leave it plugged in for? overnight?
Adam
Re: How long can I leave it plugged in [Re: cumminsexpress99] #1404828
03/19/13 01:46 PM
03/19/13 01:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have enough heat to start my diesel trucks after 20 minutes of being plugged in.
Re: How long can I leave it plugged in [Re: cumminsexpress99] #1404829
03/19/13 02:38 PM
03/19/13 02:38 PM
Kansas
cascius Offline
cascius  Offline
Kansas
Adam
Depends on how cold it is. Overnight is not a problem at all. There's stretches that I'll leave mine plugged in for days. The only drawback to this is that over time the heater can corrode and become inefficient. Other than that, it's a matter of how much electricity you want to pay for.
Re: How long can I leave it plugged in [Re: cascius] #1404830
03/19/13 06:37 PM
03/19/13 06:37 PM
I feel like the price of electricity is by far cheaper than the wear on the engine on cold starts in single digits and below.
Re: How long can I leave it plugged in [Re: cumminsexpress99] #1404831
03/19/13 07:13 PM
03/19/13 07:13 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
A thermometer goes to single didgets? Oh! You people in the colder parts of the country must have a special kind!
Re: How long can I leave it plugged in [Re: cumminsexpress99] #1404832
03/19/13 11:58 PM
03/19/13 11:58 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've plugged them in for a week at a time in camp, not necessary though. I've seen unplugged Cummins start up when a Ford diesel that's plugged in won't start.
Sheldon
Re: How long can I leave it plugged in [Re: cumminsexpress99] #1404833
03/20/13 09:45 AM
03/20/13 09:45 AM
Cincinnati, Ohio
Cincinnati, Ohio
I know of fleets that are plugged in to timers, 30 minutes on and 30 minutes off.
I have personally plugged in power strokes during 20 degree weather and have enough heat after 20 minutes to start them hundreds of times for 25 years with like 6 trucks and have never had a engine failure.
Then I have like 10 internationals that get plugged in, same deal with them, 20 minutes and they will start in 20 degree weather.
Once a year I have to clean the male plug on the trucks with a wire brush to get rid of the corrosion and the female plug on the cord has to be replaced at least once a year because they burn up from the amps that the heaters pull which is close to 1500 watts, like having your toster plugged in 24 hours a day.
I really don't think engine wear is that big of a concern from my 25 years of experience.
We usally leave them plugged in over night, sometimes on Fri night I'll unplug them to save $$ when we are not working the weekend and plug them in 1 hour before starting time on Monday morning and they always start no problem even in the coldest weather.
And I have replaced many cords on the trucks because they get burned up after a few years.
Re: How long can I leave it plugged in [Re: Challenger 1] #1404834
03/20/13 09:54 AM
03/20/13 09:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
I plugged in my freightliner last weekend for less than a hour and the Cat C-12 motor started with no problem.
Re: How long can I leave it plugged in [Re: Challenger 1] #1404835
03/25/13 02:55 AM
03/25/13 02:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can leave it plugged in as long as you want. Not like the block heater is capable of heating the engine hot enough to do any damage. As for how long you need to plug it in before cranking, well that will boil down to what kind of shape your engine, batteries, etc are in. I know with my 99 cummins 24v if I left it sitting and went to start it anything much below -5f it wasn't happy with me but would start. Now -15f unplugged forget it.
Re: How long can I leave it plugged in [Re: DaytonaTurbo] #1404836
03/25/13 11:44 AM
03/25/13 11:44 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Your grid heater wasn't working correctly. I've seen them start at -40 without being plugged in. The oil is crazy thick and not a good idea but they will start.
Sheldon
