Fan Shroud repair #1404692
03/18/13 10:16 PM
03/18/13 10:16 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Bought this shroud off ebay and when it was delivered it was broken in transit
I have not found an epoxy that wants to stick
So what to do, what to do they don't re-pop this shroud
Re: Fan Shroud repair [Re: roadhazard] #1404693
03/18/13 10:27 PM
03/18/13 10:27 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Well I figured out another way to repair it
How's it look?
Re: Fan Shroud repair [Re: roadhazard] #1404694
03/18/13 10:54 PM
03/18/13 10:54 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
How did you fix it?
Re: Fan Shroud repair [Re: skajm] #1404695
03/18/13 11:29 PM
03/18/13 11:29 PM
IN
ahy Offline
ahy  Offline
IN
I was going to suggest 2 part urethane as used on bumpers or plastic weld. How did you fix it?
Re: Fan Shroud repair [Re: skajm] #1404696
03/18/13 11:41 PM
03/18/13 11:41 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
How did you fix it?
And in only 11 minutes too. Impressive
Re: Fan Shroud repair [Re: drew72] #1404697
03/19/13 07:58 PM
03/19/13 07:58 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
How did you fix it?
Well I don't know if it's "fixed" yet
Need to get my radiator situation straightened out, install the shroud and put some test miles on it
And yes only 11 minutes to fix
