E-body Retractable Shoulder Belts Anybody? #14009
01/07/05 12:14 AM
01/07/05 12:14 AM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
I have a 71 Cuda and want to convert to retractable front seat belts like in the 73 and 74. Problem is, I would have to change the rear panels for a factory appearance, so I might just want to cut slots in the rear panels to retro-fit the mechanism. So if you have a 73 0r 74 Cuda or Challenger with these (OR HAVE ACCESS TO THE PANELS), where are the slots located on the rear panels? In other words, how far back from the lip on the panel and how far down from the window opening are the slots? ALSO, did the retraction control just the shoulder belts, or the seat belts as well (like modern cars)? Thanks in advance!
1971 Cuda, 440 custom-build
Re: E-body Retractable Shoulder Belts Anybody? [Re: BadFishy] #14010
01/07/05 12:26 PM
01/07/05 12:26 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
retractable belts were only used in 74 e bodies, not 1973. i can take a pic in my 74 cuda this weekend.
5549 post on old board
Re: E-body Retractable Shoulder Belts Anybody? [Re: 05dakota] #14011
01/07/05 12:27 PM
01/07/05 12:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it only controlled the shoulder belt, seperate retractor for the lap belt.
Re: E-body Retractable Shoulder Belts Anybody? [Re: 05dakota] #14012
01/07/05 12:43 PM
01/07/05 12:43 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Go aftermarket. I did. I wanted to do a set of 74 belts in my 71. Whata a PIA. In fact RIGHT NOW I have a complete set of 74 belts UNDER MY DESK here at work. I actually have 1-1/2 sets. they are so hard to find in decent shape I bought a complete set and some parts.
Heres a write up did from a couple other previous posts...
"First, the best way to swap them would be to get a COMPLETE set of ORIGINAL 3pt belts from a 74 E body. That was the only year E body that they came in. BUT they are expensive, since rare, usually around $200 just for the belts that are crap. THEN you also need the even rarer rear interior panels that the retractable belt came up thru. PLUS I checked, it's about $600 for Snake Oyl to restore the belts! Bottomline - this way is nearly impossible.
The way I did it. Bought the 3pt retractable with the 8" dogbone (the plastic covered steel strap that lowers the shoulderbelt down from the roof attachment point - you can see it in the link of pics I'll provide below). The company is http://www.andoauto.com/retrofit.htm The ONE PROBLEM with their belts is the plastic cover on the 12" belt/buckle that mounts to the floor beside the front seats. It's a cheesy cheap plastic cover with the wrong angle. Worst case, it IS usable but this is what I did. I searched for a correct shaped cover. There are probably many applications out there that would work. Probably even some new cars. I bought a set of rusty lap belts off Ebay for a 73 Cuda. The original plastic covers, actually more of a heavy rubber, WERE PERFECT! I did pay $40 for the set but I really wanted the installation to look correct. The complete 3pt front set was like $175 from Andover Auto. Not too bad I thought. Just a bolt in. The look and work perfect."
I can post pics tonight if interested.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: E-body Retractable Shoulder Belts Anybody? [Re: 71TA] #14013
01/07/05 06:21 PM
01/07/05 06:21 PM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
71TA, thanks for that very helpful info.
And yes, please post some pics.
Re: E-body Retractable Shoulder Belts Anybody? [Re: 05dakota] #14014
01/07/05 06:22 PM
01/07/05 06:22 PM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
ted, yes, please post some pics
thanks a lot
Re: E-body Retractable Shoulder Belts Anybody? [Re: BadFishy] #14015
01/07/05 07:58 PM
01/07/05 07:58 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The second picture shows the cheap plastic cover that CAME with the kit and the firm rubber 73 covers I used.
1399112-seatbelts new.JPG (304 downloads)
Re: E-body Retractable Shoulder Belts Anybody? [Re: 71TA] #14016
01/07/05 08:25 PM
01/07/05 08:25 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
So which one of these are the ones you ordered?
C-Bucket Seat Retractable Lap w/Shoulder Harness Set,8 1/2" Offset $65.00ea
or:
H-Retractable Lap w/Shoulder Select Buckle End From Below $60.00ea
Re: E-body Retractable Shoulder Belts Anybody? [Re: 2fast4yourBrain] #14017
01/07/05 08:30 PM
01/07/05 08:30 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I don't remember. I'll have to investigate. I think I have Alzhiemers and I'm only 42!
Re: E-body Retractable Shoulder Belts Anybody? [Re: 71TA] #14018
01/07/05 09:35 PM
01/07/05 09:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
Yeah....C or H? lol I'm going to order some for my 71 Challenger,so I'll check back later to see which ones you got.I was planning on sending a PM to see where you got your belts since I forgot This post saved me the trouble
Re: E-body Retractable Shoulder Belts Anybody? [Re: JDMopar] #14019
01/07/05 09:43 PM
01/07/05 09:43 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
It was...
(2) C-Bucket Seat Retractable Lap w/Shoulder Harness Set,8 1/2" Offset $65.00ea
and
(2) B-12" Buckle End w/Removable Hard Plastic Sleeve $15.00ea
Again I used some 73 rubber covers for the short, fixed lap bet. The plastic cover they give is unuseable.
Heres a complete set of 74 belts on Ebay in typical crappy shape BUT there are TWO SETS of the short belts with the hard platsic cover (most are cracked or ripped). Aske seller condition. Usually you on get one pair of these.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4516261735
Re: E-body Retractable Shoulder Belts Anybody? [Re: 71TA] #14020
01/07/05 09:54 PM
01/07/05 09:54 PM
Cool....thanks! I've got some 73 belts stashed back somewhere to get the covers off of.It might be easier to buy some than find mine
Re: E-body Retractable Shoulder Belts Anybody? [Re: JDMopar] #14021
01/07/05 10:46 PM
01/07/05 10:46 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Do you have to be pretty tall for those belts? I.e. do they NOT cut into your neck?
I'm 6' 3" but my wife may want to sit in my car who's only 5' 7".
Re: E-body Retractable Shoulder Belts Anybody? [Re: 2fast4yourBrain] #14022
01/07/05 10:56 PM
01/07/05 10:56 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I have a 74 challenger parts car with everything still in the car and the rear panels are in good shape ,pm me if interested.
Re: E-body Retractable Shoulder Belts Anybody? [Re: 2fast4yourBrain] #14023
01/07/05 11:06 PM
01/07/05 11:06 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I'm 5' 10" and the belt fits fine.
As for converting to 74 setup, aftermarket rear panels can be modified to look like 74 panels. But a GOOD rectangular plastic bezel that goes on the panel where the belt comes thru is pure unobtainium. I have 2 sets and both are crappy and chalky. Just BAD plastic from back in the day.
Heres some pics of a NICE, oem setup from another Moparts member....
1399618-74 belts.JPG (252 downloads)
Re: E-body Retractable Shoulder Belts Anybody? [Re: 71TA] #14024
01/08/05 12:07 AM
01/08/05 12:07 AM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
Hey guys, this is all great info. I'm going with a new set-up and not the 74 set-up. Looks a lot easier. I'll shop around for the hard rubber pieces too; its those little things in these forums that make the difference. Somebody has already been there and done that! Thanks.
Re: E-body Retractable Shoulder Belts Anybody? [Re: BadFishy] #14025
01/08/05 04:11 AM
01/08/05 04:11 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Hmmm, those OEM pics sure look familiar.
Re: E-body Retractable Shoulder Belts Anybody? [Re: G_bob] #14026
01/09/05 05:32 PM
01/09/05 05:32 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Yep they're your belt pics!
Like your Salt Flat wheels! I've been looking at some Colorado Custom Sugar Cities that are similar but UGH, $$$. Nice look!
