Fixing a wobble in steel wheels #1400131
03/10/13 11:49 AM
03/10/13 11:49 AM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
I have three 15" x 6-1/2" steel wheels that have a wobble to them.
They are in really good condition and was hoping to use them on my '68 Charger.
I mounted a spindle to my workbench and spun them to make a video.
I uploaded the video to Youtube:
http://youtu.be/f8aMoG01saM
In the video, the Sharpie pen is pointing to the rear bead of the wheel.
Thanks!
Re: Fixing a wobble in steel wheels [Re: Meangreen68] #1400132
03/10/13 12:22 PM
03/10/13 12:22 PM
IN
ahy Offline
ahy  Offline
IN
Short of cutting out the centers and re-making the wheels with new hoops I don't know a good way. Re-pop wheels would probably be cheaper.
That said, as wobbles go, that isn't terrible. I've seen worse. If you put the worst in the back, It might drive reasonably OK. Road force balance may compensate a little also.
Re: Fixing a wobble in steel wheels [Re: ahy] #1400133
03/10/13 01:03 PM
03/10/13 01:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If that's the most run out then just run them. You will never notice that.
Re: Fixing a wobble in steel wheels [Re: stumpy] #1400134
03/10/13 02:48 PM
03/10/13 02:48 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If the one in the video is the worst of them, you will probably never notice. As long as you don't put on low profile / stiff sidewall tires and or run higher pressure in them you should be fine.
I did have some wheels straightened in an old school shop years ago. They were much worse than yours. No cutting and welding, just a clamp in the center, two guys, and a huge freaking prybar with adapters to the wheel lip shape. I doubt they came out much better than what you are starting with and I ran them for years.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Fixing a wobble in steel wheels [Re: Michael Ecks] #1400135
03/11/13 05:39 PM
03/11/13 05:39 PM
Raleigh, NC
Raleigh, NC
Thanks for the input.
I found a wheel repair shop in Raleigh after calling around to a few garages.
They said they had a machine that resembles a roll bender but it's for wheels.
I have 11 wheels, 7 are close to perfect and four look like the one in the video.
I do plan to buy 15" Silvertown Redline tires for a traditional look.
I'll post a picture of the machine when I visit their shop later this week
Re: Fixing a wobble in steel wheels [Re: Meangreen68] #1400136
03/11/13 09:34 PM
03/11/13 09:34 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I recently had a tire shop tell me they couldn't balance one of the new tires on my truck because the rim had about 1/8" runout/wobble on the balancing machine?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
