2.5 or 3" exhaust? 68 dart 360
#1398702
03/07/13 05:58 PM
03/07/13 05:58 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Im putting exhaust on my dart, mostly stock 360. In a few years I'm planning on a 408 stroker. Should I go with 2.5 or 3" exhaust?
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 2.5 or 3" exhaust? 68 dart 360
[Re: rapom]
#1398705
03/07/13 06:56 PM
03/07/13 06:56 PM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
2.5" is plenty as the guys in the fast series are running 2.5" and running in the 9's
fixed
I think 3" would be too much on a 360 ... then again they put 5" on a 5.9 cummins
[Re: rapom]
#1398706
03/07/13 06:58 PM
03/07/13 06:58 PM
Posts: 646 VA.
mosweethemi
VA.
[Re: GTSDart340]
#1398707
03/07/13 07:23 PM
03/07/13 07:23 PM
RapidRobert
3". I believe any neckdown aft of the header collector restricts flow & therefore hurts power & you want no restriction & the least amount of backpressure from there rearward in a 4 stroke eng. Gas speed/scavenging is a seperate pri tube dia/length issue. But a 3" setup is going to be VERY loud & you'll need every ex trick in the book to make the noise liveable, X pipes, addit'l glasspack muffs alongside the leaf springs & maybe add some sideways capped 1.5 ft long pipes welded to the 2 bends over the axle (helmholtz resonators iirc). Ain't tried it but reportedly it is an accoustical godsend for noise reduction. Best might be those trick muffs that open up when you get on it I forget what they are called or some cable or electric operated cutouts along with restricted muffs (keep em quiet till the money is in the hands of a neutral 3rd party ). 2.5" would be troublefree. 3" would be a certain amount of gain but would be alot more work/planning. Mandrel bends everywhere.
[Re: GTSDart340]
#1398708
03/07/13 07:43 PM
03/07/13 07:43 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Don't bother with 3" unless you plan on over 500hp. Also, don't negect the muffler selection. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1398709
03/07/13 08:01 PM
03/07/13 08:01 PM
Posts: 2,578 sweden
1Fast340
sweden
whats the point in building a 408 if you are not shooting for that kind of power?
i say go for it and like said before chose the right mufflers for it! 3" usualy gives a nice deep sound
[Re: DPelletier]
#1398710
03/07/13 09:05 PM
03/07/13 09:05 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
x2
[Re: pinkduster]
#1398712
03/07/13 10:01 PM
03/07/13 10:01 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
As usual the original poster didn't really indicate what his intended use for the car will be. Is it a race only drag car, or a weekend cruiser, or a daily driver.
As others have stated, 3" will be very loud inside the car. And in my opinion is overkill. But if your just racing who cares how loud it is. If its a driver or a cruiser, the loud pipes can get old very quickly.
I read an article a couple years ago and i'll try to relay what it said even though I may be using the wrong scientific terms. But basically what its said was the by the time the exhaust gets through the mufflers, a large portion of the heat energy has been disapated, or maybe it was back pressure, anyway, it stated that you could do like 3" pipes from the headers to the mufflers, and then go 2.5" from the muffers out the back tailpipes and you wouldn't really be creating any extra back pressure by having the smaller tailpipes. But the car would be quieter with the smaller tailpipes. Wish I could find the article, I'm sure its explains it better than I did.
Anyway, I would stick with 2.5" pipes if the car sees any amount of street use, just to keep the noise down.
Good luck
[Re: MileHighDart]
#1398713
03/07/13 11:02 PM
03/07/13 11:02 PM
GTSDart340
Laveen, Arizona
Its going to be a street car, but not a daily driver.
[Re: GTSDart340]
#1398714
03/08/13 12:47 AM
03/08/13 12:47 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
I see you came to ask the professionals. I think 2.5" would be plenty. You will be fast enough, and light enough, to beat all your brothers and their GM cars.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: GTSDart340]
#1398715
03/08/13 01:00 AM
03/08/13 01:00 AM
Posts: 5,302 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
I went through this same thing last summer with my Duster! I have a mild 360 currently as well. I debated and went back and forth for weeks... deciding on what to do. Since mine is just a weekend summer cruiser (car show/cruise nite/ice cream runner type Mopar)...I went with a header back Jegs(Pypes) full 2-1/2 inch kit which is a nice kit IMO. All aluminized mandrel pre-bent tubing with (optional H-pipe) which I got. I wanted to go the full exhaust route, with 2.5" stainless steel tips. I had a local muffler shop do the work,because I wanted everything welded properly. They had an easy time until they assembled the 2.5" tailpipes next to the factory gas tank. It took them quite awhile to get the fitment just right on the pass. side pipe...between the tank and leaf spring. IT'S TIGHT THERE! The system turned out great though,sounds awesome with Flowmaster 2 chambers. So....if you are thinking of going with a 3 inch system out the back...think twice about the gas tank issue! Good Luck!
Plymouth Makes It!
[Re: RoadRunnerLuva]
#1398716
03/08/13 04:29 PM
03/08/13 04:29 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
Yep I put that kit on my 73 swinger- the passenger side over-axle isn't quite right. I had to do some surgery to get it right. Still was cheaper and easier than going to the local shop with a non-mandril bender that's going to try and sell you flowmaster 40s!
[Re: MileHighDart]
#1398717
03/08/13 04:47 PM
03/08/13 04:47 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Good luck
Have read similar articles and his summation is not far off.
Tailpipes are an oft-overlooked key in noise control. Size and location of the turndown are key.
[Re: pinkduster]
#1398722
03/08/13 09:54 PM
03/08/13 09:54 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
When I bought my 1974 360 Challenger it had 3" pipe and flowmasters off the headers. It was loud, and gutless. I bought one of the Jegs $200 mandrel bent exhaust kits with mufflers in the 2.5" size. The car picked up quite a bit and sounded better out of the exhaust tips.
I am lowering the car, removing the headers, and putting '70-'71 high flow factory exhaust manifolds on it. I will make up the required pipe to join up to the Jegs setup and will likely add a set of electic cutouts for fun (that might exit something like the T/A pipe).
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: GTSDart340]
#1398726
03/09/13 11:25 AM
03/09/13 11:25 AM
Posts: 4,941 WI
Dcuda69
WI
[Re: Challenger 1]
#1398727
03/09/13 11:39 AM
03/09/13 11:39 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
3" is just silly for a 408, even more stupid for a 360 in a dart!!
You guys are a riot.
Call me silly. I get a kick out of some of your stuff too .
My 340 was about 450 hp, hydraulic cam and pump gas. It had 2 1/2" with flowmaster 40s with turn downs at the rear end. I bracket race the car some and had always run it with the exhaust off and deciced to leave it on one night to see what it would do. It was late in the fall and the air was great, in the first round of open time trials all of my friends ran near their best times. I went out and the car ran 7.45 when it should've been in the 7.20s. When I pulled into my pit I put the ramps on tha trailer and pulled the car on them and took the exhaust off. Went right back out and ran 7.26, the best it had ever ran was 7.24. Now keep in mind that my exhaust turned down before the rear end, no bends over the rear end. This was real back to back runs 10 minutes apart, not some keyboard B.S.
The 408 in my car now is around 550 hp on pump 93 and has 3" exhaust turned down at the rear end, it has gone 6.70 with the exhaust and 6.57 without. Not on the same night so I can't say it's holding it back. I drive this car a lot in the summer, there is no resonance at any rpm and it's only loud inside when I gouge on it.
[Re: justinp61]
#1398728
03/09/13 11:51 AM
03/09/13 11:51 AM
Challenger 1
Cincinnati, Ohio
He said his was street car, not a race car. 3" system is heavier than a 2.5" pipe. A dart is a smaller car than my challenger with 3" and it's tight under my E body. I don't care for my 3" X pipe TTI system and my 2.5" H pipe TTI pipes sound way better than the 3" X pipe, way better. I have BB in my 3" car, not a little wimpy 408.
Bigger is not always better is my point, especially for street car. Been there, done it.
[Re: Challenger 1]
#1398729
03/09/13 12:07 PM
03/09/13 12:07 PM
justinp61
W. Kentucky
[He said his was street car, not a race car. 3" system is heavier than a 2.5" pipe. A dart is a smaller car than my challenger with 3" and it's tight under my E body. I don't care for my 3" X pipe TTI system and my 2.5" H pipe TTI pipes sound way better than the 3" X pipe, way better. I have BB in my 3" car, not a little wimpy 408.
Mines a street car too. What does the bad big block Challenger run? 8.20?
[Re: justinp61]
#1398730
03/09/13 12:18 PM
03/09/13 12:18 PM
Challenger 1
Cincinnati, Ohio
I have no idea what it runs because I have never taken it to the drag strip. Even a 10 second ride is not exciting to me anymore on the track. On the street is totally different story. Now it's about cruising in a reliable muscle car for me. My 440 has eddie heads on it and a 6 pak. It'll smoke my 12" wide mickeys at 35 MPH roll.
I just got a go pro camera for Xmas and wanted to use it today but it is still too salty on the streets. I've been downtown and to work already today on separate trips checking out the streets because it's going to be 55 today and the rest of the snow will melt. It's gonna have to wait. My cars are no slouches but I'm not claiming to have the fastest car.
[Re: pinkduster]
#1398731
03/09/13 12:54 PM
03/09/13 12:54 PM
JohnRR
U.S.S.A.
you should have stayed with this post only ...
[Re: JohnRR]
#1398732
03/09/13 04:54 PM
03/09/13 04:54 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
YEAH, I know! All this talk about pea-shooter sized exhaust is quite entertaining though.
[Re: justinp61]
#1398734
03/11/13 04:47 PM
03/11/13 04:47 PM
DPelletier
I bet those crappy flowing Flowmasters cost you far more restriction than the 2.5" pipe does/did
1974 'Cuda
[Re: Dr-Dave2]
#1398737
03/12/13 10:07 AM
03/12/13 10:07 AM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
The DynoMax tech section has some good information about calculating exhaust diameter based on C.I,D. and horse power seems like muffler selection is also a factor in their calculations http://www.dynomax.com/assets/2012catalog_pdf/2012_Dynomax_techsection.pdf
As per DynoMax tech piping chart about horsepower. It is brake horsepower or rear wheel horsepower. Big difference... My engine is a 451 with 373 RWH and I use 3.00 may be It's too big.
