Re: My windshield wiper motor "?"
[Re: sthemi]
#1395229
03/01/13 12:41 AM
03/01/13 12:41 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
try cleaning the ground wire connection off before you buy anything... Mine was pretty bad, I think I had to cut it off, strip wire and make a connection. then it parked properly.
Thanks, I'll give it a try. The location of ground wire?
[Re: bigblock340power]
#1395230
03/01/13 01:37 AM
03/01/13 01:37 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
should be a ground strap off the wiper motor to 1 of the mounting studs IIRC.
I am truckless..
[Re: 340SHORTY]
#1395231
03/01/13 02:53 AM
03/01/13 02:53 AM
Posts: 85 Rio Linda, CA
nytemuvr
Rio Linda, CA
If the grounding suggestions don't work, the "park" switch inside the wiper "transmission" has broken, they used to have rebuild kits for them, but you may be hard pressed to find them anymore.
1972 Challenger 340(original owner)
1968 D100
1997 HD Road King
[Re: nytemuvr]
#1395232
03/01/13 04:27 AM
03/01/13 04:27 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Sorry, It is a brass strap that needed to be cleaned up.. The other wire I was remembering was the fan motor ground. Both had issues...
