Taillight wiring/Converting pickup to a trailer ? #1394614
02/28/13 02:10 AM
02/28/13 02:10 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have a ratty old longbed truck that I'm converting into a trailer. My question is in regards to the taillight wiring. I'll be using a 3&1 4 pin connector. Am I to guess that one wire is for the left light, one is for the right, one is for brakes and the solo one is a ground?
Thanks, Greg
Re: Taillight wiring/Converting pickup to a trailer ? [Re: Kern Dog] #1394615
02/28/13 02:54 AM
02/28/13 02:54 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
http://www.etrailer.com/faq-wiring.aspx
You are almost correct.
Green - right turn
Yellow - Left turn
Brown - marker & tail
White - ground
The turn signal light circuit also functions the brake lights.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Taillight wiring/Converting pickup to a trailer ? [Re: hp383] #1394616
03/19/13 06:25 AM
03/19/13 06:25 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thank you so much.
