Re: My 360 oil pan gasket
[Re: 340SHORTY]
#1394241
02/27/13 09:09 AM
02/27/13 09:09 AM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
I have a 360 crate short block in 11secdart and always had a problem with leaking pan gaskets until I put in the stock replacement 360 magnum gasket with right stuff, no problems ever since.
[Re: 76dodgeboy]
#1394242
02/27/13 11:44 AM
02/27/13 11:44 AM
Posts: 77 Louisiana
rnch
Louisiana
360 is different than 318/340 Oil pan only fits 360.
ooohhhhh!!!!!!! Learned sumpin' new today.
[Re: 340SHORTY]
#1394243
02/27/13 12:00 PM
02/27/13 12:00 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
I have the MP version on my 340. I absolutely love it. Been on there for 11 years now and not a drop 1 of leakage..
Part # please..........
[Re: rnch]
#1394244
02/27/13 12:44 PM
02/27/13 12:44 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Yeah I learned the "hard" way. I was new to mopar. Bought a truck my dad had for when he did some work to his house. Needed an oil pump and bearings. He was told by po it was a 318 but I found otherwise when the bearings didnt match and the pan gasket was diff. I believe its just the rear seal thats diff. 318s use the same front and rear and 360 is a smaller rear but I could be backwards that was 8-10yrs ago
[Re: rnch]
#1394246
02/27/13 02:51 PM
02/27/13 02:51 PM
bigblock340power
Elk Grove, Calif.
If using the 4 piece oil pan gasket set, what (if any) sealant is recommended to use to give a (hopefully) leak free seal?
I just use a bit of Silicon (RTV, high temp) in the 4 cnrs. Works fine.
[Re: 340SHORTY]
#1394248
02/27/13 09:35 PM
02/27/13 09:35 PM
bigblock340power
Elk Grove, Calif.
Sorry, that was 11 years ago..
Figures!........
