Oil filter length: Can I use a bigger/longer filter? #1394190
02/27/13 12:21 AM
02/27/13 12:21 AM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
'85 318 D-150.
Is there a larger/longer filter than I can use?
Re: Oil filter length: Can I use a bigger/longer filter? [Re: rnch] #1394191
02/27/13 12:32 AM
02/27/13 12:32 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
What is on there now? It probably calls for a (Wix) 1068. If you have the room, you can run a 1515.
It's Swifty! Swifty, you toad sucker!
Re: Oil filter length: Can I use a bigger/longer filter? [Re: zrxkawboy] #1394192
02/27/13 02:08 AM
02/27/13 02:08 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Should be fine. Only issue would be exhaust but its not that tight of a spot.
He might not use wix
Re: Oil filter length: Can I use a bigger/longer filter? [Re: 76dodgeboy] #1394193
02/27/13 11:39 AM
02/27/13 11:39 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
This is one area where parts houses have changed over the years. I can remember when I was kid parts people would ask my dad do you what long or shot before going back to get it the oil filter.
I guess with these newer ones there isn't much room like there used to be. Like my 02 Dakota v6 is tight.
I understand wanting a longer/bigger filter.....I do put the long wix 51515 on my 05 Chrysler Town & Country mini van. My Dakota calls for the real short one. I'm able to put the 51068 part # on it instead of the.51085 part # it's tight though.
Moparlee
Re: Oil filter length: Can I use a bigger/longer filter? [Re: Robbins] #1394194
02/27/13 12:05 PM
02/27/13 12:05 PM
scratchnfotraction Offline
I have used a 2quart filter from a perkins diesel engine or the 1515 from wix.
I have run the long and short mini filters on them with headers, they were motocraft filters for a ferd 3.0 engine.
as long as you match up the nipple thred size and rubber o-ring seal size it should work.
I like the 2quart from the perkins diesel engines myself.I will be getting one for the 440 truck next oil change.
have napa cross referance it for what ever brand filter you want to buy.
Re: Oil filter length: Can I use a bigger/longer filter? [Re: Robbins] #1394195
02/27/13 12:43 PM
02/27/13 12:43 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Yes, I also can recall hearing the same question 30, 40 years ago when tagging alond with my Dad at the local parts store.
My '85 ram 318 has the stock exhaust system; it looks like a longer filter will clear the pipe.
I've always read/heard that the more filter square footage area the better. Is this still true in 2013?
Re: Oil filter length: Can I use a bigger/longer filte [Re: rnch] #1394196
02/27/13 03:49 PM
02/27/13 03:49 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Yeah, if you enjoy throwing away good unused filter material, sure.
