Re: Forged Crank Question...
[Re: Lighthorseman]
#1393346
02/26/13 02:28 AM
02/26/13 02:28 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
You need a hole to put it in...in the back of the crank, some auto cranks did not have it. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Lighthorseman]
#1393348
02/26/13 10:32 AM
02/26/13 10:32 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I've heard that a cast crank just isn't going to cut it.
First of all, let's go back to square one when everybody else is running off in a 100 different directions like chickens with their heads cut off. Your forged crank is going to cut it unless you're having someone build you a 600 hp engine that you're going to do 8k rpm test & tune runs on Friday nights. Another case of a little knowledge is a dangerous thing.
Secondly, if you say "a cast crank just isn't going to cut it" because it won't accept a 4 speed, there's a simple work-a-round solution to that by machining off the the end of the tranny input shaft and using a special order bearing from NAPA or some other places.
Third, if you already have a forged crank, MOST likely it will accept a 4-speed. Simply look to see if there is a hole at the end of the crank. If not, see #2.
Finally if you have a forged crank with the hole, go to town with it.
The forged and the cast cranks each use different flywheels, btw.
[Re: Commando1]
#1393349
02/26/13 11:15 AM
02/26/13 11:15 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
SPECIAL ORDER ???
If a crank is not finished reamed there is a bearing that is used in a Dakota that can be used and it's not special order as far as I know. :shurggy:
How much of the input shaft needs to be TRIMMED is ona case by case basis , measure once cut twice ... or is it measure twice cut once ???
[Re: Commando1]
#1393351
02/26/13 02:20 PM
02/26/13 02:20 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I believe the NAPA adaptor pilot bushing is discontinued. Mainly because of the pilot bearing that JohnRR mentionned that works better and is only slightly more expensive.
[Re: Commando1]
#1393352
02/26/13 04:31 PM
02/26/13 04:31 PM
JohnRR
U.S.S.A.
Actually you're correct. I meant "special order" in the sense you probably won't be able to walk into NAPA and find one in stock on the shelf.
The unit for the Dakota should be an in stock item , the pilot bushing for a 1970 would have to be ordered more likely ?
[Re: JohnRR]
#1393353
02/27/13 02:50 PM
02/27/13 02:50 PM
Posts: 41 Sherwood Park, Alberta, Canada
Lighthorseman
Thanks for all the info, everyone! I have a 2843212 flywheel, which, I believe, is an 11 inch, 143 tooth unit. Someone mentioned it was "neutrally balanced", and someone else said that it is likely an internally balanced one.
Then, the crankshaft apparently "might" be a pre-1962 crank which is no good for going in anything post '62. Also, there is a possibility that it might be an "extended flange" unit, which wouldn't work either.
Holy smokes, am I ever confused. I'm going to go look at the thing today and see if the bolts match up 'twixt the crank and my flywheel. If I'm still not sure, I'll just get LOTS more pictures and ask for help.
Thanks to everyone up to this point! - Steve -
