4 speed bell housing alignment questions
#1392781
02/24/13 01:54 PM
02/24/13 01:54 PM
Posts: 755 Oregon
moparmedic
My 70 Challenger is my first 4 speed car and I am reading a lot of stuff about bellhousing alignment in the shop manual and in the clutch kit I got. Anyone have any tips on getting this right the first time? Is it common to have to get the offset dowel pins and all that? Good pictures would help, the shop manual isn't as clear as I would like, or maybe it is and I don't quite understand it.
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
Re: 4 speed bell housing alignment questions
[Re: moparmedic]
#1392782
02/24/13 02:13 PM
02/24/13 02:13 PM
Posts: 18,157 Mass
DAYCLONA
Mass
While most just throw the factory stuff together, as the tolerances are that "loose", it doesn't hurt to check the runout of the components involved, and improve upon their fit and performance, mock up your stock bell, or the bell your using, and indicate the bore opening in relation to the crankshaft, check crankshaft endplay to see if that's an issue for your current engine, run an SFI approved flywheel, toss the factory flywheel,...check to see if your crank is drilled for a bushing?, if not, it bearing time, and trimming of the input shaft...other items that always need addressing is the factory Z bar set-up, lots of slop and alignment issues,that can be eliminated... I'm sure others will chime in to help, don't hesitate to post questions or ideas/thoughts Mike
[Re: DAYCLONA]
#1392783
02/24/13 02:23 PM
02/24/13 02:23 PM
RapidRobert
What Mike said, Have someone help you setup/dial indicate it & post what you get for runout. I wouldn't think the shop manual would have detailed info on that. Not needed in every case but you are at that point so I'd bite the bullet & do what you need to do to get it checked. then you know you're good & the peace of mind is worth it
[Re: JohnRR]
#1392787
02/24/13 03:52 PM
02/24/13 03:52 PM
Posts: 755 Oregon
moparmedic
Good tips, thanks guys! I do have a magnetic base dial indicator. I will get it set up and check and post results today.
Yes the car is an original 4 speed car but the engine is not original to the car and I am not sure about the bellhousing. It was sitting in the trunk when I bought the car.
[Re: Cab_Burge]
#1392790
02/24/13 08:32 PM
02/24/13 08:32 PM
Posts: 755 Oregon
moparmedic
The engine is mostly together. This is what I came up with. Does my set up look correct? The readings are 0 top and -.016 bottom. Left side was -.008 and right -.009. I checked it twice. Let me know if that looks and sounds right. Thanks for the help......Frank
[Re: 67_Satellite]
#1392792
02/24/13 09:23 PM
02/24/13 09:23 PM
Posts: 755 Oregon
moparmedic
I assume this is outside of acceptable tolerances right? If so,does the bellhousing get adjusted up or down? The video that was linked with similar results said down. I would buy the .007 offset pins correct?
[Re: moparmedic]
#1392793
02/24/13 10:08 PM
02/24/13 10:08 PM
Posts: 8,860 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The side to side will not change if you just move the housing up or down - really, how can it ?!? You're out .001 now, you'll still only be out .001 when you move the housing up or down.
To fix your problem you need the .007" dowels. PM me and I can help you out there. As for up or down, that depends which way it's out. Your + or - means nothing to us. If the bottom is .016 further from the center then it needs to go up. If its .016 closer then it needs to go down. Either way you need the .007 dowels and when you install them you'll know soon enough which way it had to go. If you did it wrong they're easily turned with a screwdriver.
[Re: 6PakBee]
#1392795
02/25/13 12:00 AM
02/25/13 12:00 AM
Posts: 755 Oregon
moparmedic
Perfect! Thanks for the help!
[Re: moparmedic]
#1392796
02/25/13 12:06 AM
02/25/13 12:06 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Dont waste your money on the fixed dowels, get the RobbMC adjustable dowels, it will make the alignment so much easier. I spent 4 hours and went through 3 sets of fixed dowels to get it right before I got the adjustable ones and WOW, it was a few minutes and I was within .003 TIR and the parallel was within .002 Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1392797
02/25/13 12:15 AM
02/25/13 12:15 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
ah bullsh!t !!!
How hard can it be ... he's virtually dead on side to side and out .008 up and down. This doesn't take a rocket scientist, a bag of cash and fancy gadgets to fix !!!
[Re: Stanton]
#1392798
02/25/13 02:05 AM
02/25/13 02:05 AM
Posts: 755 Oregon
moparmedic
I needed several other transmission related items so I just ordered a set of offset pins from Brewers. Hopefully get this thing all lined up and back in the car. It has not been on the road since the early '80s!
[Re: Stanton]
#1392800
02/25/13 11:49 AM
02/25/13 11:49 AM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
ah bullsh!t !!!
The Lakewood dowels are .500 , Mopar dowels are .496 , that's .004 oversize then you take the fact that its a press fit hole so those are more than .004 oversize. Unless you ream out the holes in the block the dowels will NOT turn with a screwdriver and you run the potential of cracking the block, more than once I have seen that posted by someone. I've used those dowels ONCE, they DO NOT turn once you hammer them into the block.
It's not rocket science , but it also takes a little more than what a caveman with a large rock for a hammer can do ...
[Re: moparmedic]
#1392801
02/25/13 11:52 AM
02/25/13 11:52 AM
JohnRR
U.S.S.A.
Looks like the RobbMC dowels ,I'd put loctite on the set screws for the final assembly.
[Re: Stanton]
#1392803
02/25/13 02:10 PM
02/25/13 02:10 PM
astjp2
Utah and Alaska
I would check the parallel of the mating surface of the bellhousing first, I had mine dead nuts at .002 tir and found my bell was not parallel so I had to put in a shim between the block and bell. When I did that, it totally screwed my number and I had to start over again. I tried the lakewoods and wound up drilling and slide hammering them out. I finally just ordered the Robbmc ones and within a short period of time after I got them it was within book spec. Tim
[Re: astjp2]
#1392805
02/25/13 02:42 PM
02/25/13 02:42 PM
JohnRR
U.S.S.A.
I would have run it up to the machine shop and had them surface it .
Also that brings up a good point , the picture the OP put up shows his dial indicator is not inside the bore of the bellhousing ... at least it looks that way ??? but the picture is small ... if that is the case he isn't really getting an accurate reading...
but probably close enough for a caveman ...
[Re: 67_Satellite]
#1392808
02/25/13 07:54 PM
02/25/13 07:54 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Because you will be measuring closer to the center of the circle,not .008 off center.It will still be centered l to r the same but the number will be a few thou different
Hmmm ... you're measuring at the widest point and then shifting it up .007". Do you really think the number will be "a few thou" different? I'll bet you the change doesn't show up on the dial indicator!
As for John having it surfaced ... another instance of him needlessly spending someone else's money. Yes, by all means check the runout, but if it is out of whack its easily resolved with shims cut from feeler gauges or pop cans instead of dishing out $100 to have it surfaced.
[Re: JohnRR]
#1392810
02/25/13 08:29 PM
02/25/13 08:29 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Pop can, beer can, piece of steel roofing , what does it matter if it works. My question as I have never heard of machining the bell housing to be parallel with the block, which surface gets re-surfaced ? the block side or the transmission side. I think a person can micro a project to death trying to get something perfect when there is tolerance that is acceptable .
[Re: JohnRR]
#1392812
02/25/13 11:45 PM
02/25/13 11:45 PM
Posts: 755 Oregon
moparmedic
I could not get my set up adjusted so that the indicator was fully centered in the bore but it is inside the bore. The picture was taken looking slightly down and from the left. The part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
[Re: moparmedic]
#1392813
02/26/13 12:07 AM
02/26/13 12:07 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I could not get my set up adjusted so that the indicator was fully inside the bore but the part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
Your setup is fine. Maybe one in 50 people will have a dial indicator and stand that will actually fit inside that hole! So the indicator is at a slight angle ... big deal, as long as it stays that way throughout the entire travel around the hole it doesn't matter.
And John, the proper surface to machine would be the trans mounting face, not the block face. The main reason being that less material would have to come off but also there would be a good chance of cracking an iron housing if it is taken off the block face.
[Re: Stanton]
#1392814
02/26/13 12:15 AM
02/26/13 12:15 AM
Posts: 755 Oregon
moparmedic
Ok, good,that is kind of what I thought, thanks.
[Re: Stanton]
#1392815
02/26/13 12:20 AM
02/26/13 12:20 AM
rowin4
Yes his set up is correct. A standard size indicator will not fit inside the hole straight up. The surfacing of the bell housing would be easier to do the transmission face only if the block face was flat.
[Re: Cab_Burge]
#1392819
02/26/13 02:00 AM
02/26/13 02:00 AM
Posts: 755 Oregon
moparmedic
The results I got were surprisingly similar to the you tube video link that was attached earlier in this thread. Yes, I zeroed the dial indicator at 12 o-clock and called that zero then took a reading at 3, 6, and 9 o-clock. The you tube video showed taking readings more frequently. http://www.youtube.com/watch?v=tS4H4oImDhE
[Re: moparmedic]
#1392820
02/26/13 02:11 AM
02/26/13 02:11 AM
rowin4
I have always set the indicator to zero at the lowest reading, by doing that you don't have the + and - readings confusing you. I do the 45 degree, use a marker on the bell housing face, take a 360 reading , do a adjustment , do it again and again and again. wish I had a friend to do the wrench cranking
[Re: rowin4]
#1392821
02/26/13 02:19 AM
02/26/13 02:19 AM
Posts: 755 Oregon
moparmedic
I set it at zero at the top. The way it was explained, deflection to to the right of zero was negative and to the left of zero was positive. All of my deflections were to the right. As the tech in the video explained (and assuming he is correct), I would need to move the bellhousing downward to get it within tolerances. I only took readings every 90 degrees not at 45 degrees.
[Re: astjp2]
#1392823
02/26/13 02:29 AM
02/26/13 02:29 AM
Posts: 755 Oregon
moparmedic
I guess I need to check that after reading all of tonights posts. The service manual shows (chronologically) checking the bore first and then parallel so I didn't give it much thought until tonight. The video did the same.
[Re: moparmedic]
#1392824
02/26/13 02:44 AM
02/26/13 02:44 AM
astjp2
Utah and Alaska
Well mine changed when I shimmed it. I have washers that are precision shims, they are .006 thick. If you need a few PM me and I will try and get them out to you in the mail. tim
[Re: ThermoQuad]
#1392828
02/26/13 05:17 PM
02/26/13 05:17 PM
Posts: 2,360 PA
70HemiGTX
PA
The bell housing needs to be attached with all of it's fasteners & torqued properly before checking runout and squareness. It makes a BIG difference!!!!!
All mating surfaces should be bare metal with no burrs
If you ever wonder why some cars are faster than others...it's in the details....
I couldn't believe how much paint was on both surfaces when I went to put them together. It all adds up. I scraped them down and just barely dusted the bellhousing and block plate with paint and a little light grease on the block so they wouldn't rust.
[Re: 70HemiGTX]
#1392829
02/28/13 01:03 PM
02/28/13 01:03 PM
Posts: 755 Oregon
moparmedic
Checked the bellhousing for parallel yesterday. I had a hard time getting consistent readings so I had to change the set up a couple times. Must have checked it at least 6 times when it was all said and done. In the end, the greatest total run out I had was .005. The shop manual says to make corrections if total run out is.006 or greater. Now I am just waiting for my offset dowels which are scheduled to be here tomorrow. Hopefully I can have this wrapped up and in the car this weekend or early next week.
[Re: rowin4]
#1392832
03/02/13 10:26 AM
03/02/13 10:26 AM
JohnRR
U.S.S.A.
I have been thinking again on the alignment question also. I don't see that the block surface would be off at all. As for the bell housing, maybe the stock aluminum might be contorted after 40 years and have either block facing or the transmission facing out of whack. I have the tools to check it but ain't gona do it. Indexing the center is good enough.
Why wouldn't the block surface be affected after X thousands of heat cycles the same way the cam tunnel , the main line and the head deck surfaces are ?
[Re: JohnRR]
#1392833
03/02/13 08:00 PM
03/02/13 08:00 PM
Posts: 755 Oregon
moparmedic
Finally got my offset dowels. I had a hell of a time getting one of the old ones out but finally won that battle. Installed the dowels so that the bell housing moved downward .007 and my runout was no more than .002 top to bottom and within .001 side to side.
Thanks for all the help!!! Now I can bolt the tranny up and get the engine in the car....I think...
[Re: mickm]
#1392836
03/03/13 01:46 AM
03/03/13 01:46 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
ok, my turn. i set the dial indicator and then turned the crank 90 deg each time. set the indicator at 0 at 6:00, and these were my readings the first time around:
0 .014 .001 -.012
did the setup again for out of round and got:
0 .012 .002 -.013
so, i have some .007 offset dowels. do i wait and get some .014's or do i just go for the .007? that will put me within range. FSM says .008, and the Robmc dowels I have say .010.
what would you do?
Okay, if I understand what you did, bottom = 0, left = .012, top= .002, right = -.013. TIR vertically is 0.002, off center is 0.001, no change necessary. TIR horizontally is .025, off center is .0125. The 0.014 dowels would get you within about 0.0015 off center, the 0.010 dowels within about .0025 off center. I'd use the 0.014 choice. But I'm anal.
[Re: 6PakBee]
#1392837
03/03/13 03:49 AM
03/03/13 03:49 AM
Posts: 4,179 California
mickm
California
i think anality wins out here. i agree. i may as well go for it and get it as close as possible, and yes, if i also understand things correctly, what you have stated above is correct.
well, only one more week while i wait for parts!
until the next snafu, that is!
[Re: moparmedic]
#1392839
03/26/13 08:24 AM
03/26/13 08:24 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
All my pains of alignment checking issues have been Simplified ..!
[Re: sogtx]
#1392840
03/26/13 10:54 AM
03/26/13 10:54 AM
JohnRR
U.S.S.A.
[Re: mickm]
#1392841
04/09/13 09:41 PM
04/09/13 09:41 PM
sogtx
upstate western ny
Ugh .. What a pain in the butt , the browell tool checks Squareness and alignment , best 130 i ever spent .
[Re: fuseable]
#1392849
04/10/13 06:48 AM
04/10/13 06:48 AM
sogtx
upstate western ny
I machined mine myself to match ( it came chevy style ) the id of the retainer opening . Mine us verrrry tight . +~ a couple thousandths If your bh is not square , theres no way the collar is slipping on and through . The collar is about an inch Thick . Thats enough to know if youre square and concentric . If you really want to second guess square a flat Edge across the bh and collar to verify any high spots .
If youre not square , then you may need to break Out with the the correct measuring tools to shim and tgen check with the browel tool , but .. Youre more likely to be using dowels than shims .
I wouldnt want to shim for squareness ..
My clutch shop in rochester here said that Many bellhousings have been decked perfectly flat by machine shops. But not much to shave off before causing other problems. If youre block is not square , then either you should reblueprint Or i guess shim ..
[Re: sogtx]
#1392850
04/11/13 11:58 AM
04/11/13 11:58 AM
JohnRR
U.S.S.A.
I have the 383 for my stroker in getting some work right now and I'm having the shop kiss the bellhousing surface to make sure it is parallel to the crank line since the block was either align honed or align bored , don't remember which.
If it's not square then I know it's the bellhousing and I'll deal with it .
[Re: Stanton]
#1392852
04/11/13 08:17 PM
04/11/13 08:17 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
It's always a good idea to have an aftermarket steel bell blanchard ground just to make sure that part of the drive train is correct. That way if you do have a clutch issue or premature bearing wear you know what it isn't I have seen a fair number of posts on here about guys that have found the block face not square with the crank flange I checked my last 2 builds that I knew were going to be stick cars and they were both just under .002 measured with a "known good" bell and my own tool that holds the dial indicator very rigid bolted to the crank instead of a mag base unit. My point being as long as you know the bell is flat and true you can trust your measurements at the retainer pilot Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#1392853
04/11/13 10:29 PM
04/11/13 10:29 PM
sogtx
upstate western ny
I'd be curious to know what machine the average automotive machine shop would use to end-mill a block. Likewise, I'd like to know what the fixture to hold it looks like since you'd want to register off the main bores.
With all this talk about the block not being square (which I find hard to believe), why hasn't anybody suggested checking it ?!?! It can be done very easily with the dial indicator and magnetic base using a slightly longer arm to get the indicator out to that block surface. This is a hell of a lot less hassle and way cheaper than having sh!t machined on a whim!
Not sure what you referred to on a whim , but whatever . Maybe shoddy machine work on a block. ? I hate setting up the gage, my time is valuable . And i refuse to use a harbor freight gage. if referring to my no brainer gage , its saved me hours And its reliable and cheap.
The prostockers / top fuel guys use it on every round . A couple thousandths might mean a 10 th . Or more.
it would be nice to machine a bolted fixture to hold the dial indicator. Magnetic bases do suck . Someone once told me you Should repeat the procedure 2-3 times to make Sure it bolts together the same way each time . A little paint on the mating surfaces might throw it off.
I guess a good machine shop would be able to square a block Or Anything up , but i guess off the crank is probably The truest measure to gage off. I guess thats why some guys Run remarkable times , some have all the hp in the World and run crap . Some clutches and pilot bearings last years , some only a couple .
[Re: Stanton]
#1392854
04/12/13 01:08 AM
04/12/13 01:08 AM
JohnRR
U.S.S.A.
sogtx , I'm sure he is bagging on me ... as usual
The shop that has my block has a Rottler 769 machining center , same or similar to what Chenoworth was using for their "Block in a Bag" fully remachined block offer , and the same that Performance Only caught a load of crap for because he didn't offer it up first .
I'm ASSuMEing they are registering this off the main line , I'll be on the phone in the morning giving them the size of the Crane rollers so they can hone the lifter bore bushing to size so I will make sure that they are doing this off the main line , the mains on this block have been reworked so I want to make sure that the rear of the block is perpendicular to the crank line as the car is a 4 speed and I don't want to have to cut up the nickle deposit return soda cans to correct it ...
The other 383 I just had decked was not square on the decks , and neither was this block, if the decks are off why would, or should, I ASSuME that all the other machined surfaces are square?
[Re: sogtx]
#1392855
04/12/13 06:38 AM
04/12/13 06:38 AM
Posts: 2,360 PA
70HemiGTX
PA
I went and bought a long bolt, removed one of my flywheel bolts, and threaded it in to mount my dial indicator. Those wonderful magnetic bases kept moving on the flywheel surface. I then used hose clamps and secured one of the "arms" that came with the dial idicator to it so that nothing moved and then got some real readings. It didn't take long once I got this accomplished and had real readings I could trust.
[Re: Stanton]
#1392859
04/29/13 01:13 PM
04/29/13 01:13 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Another Rottler user here. On the F-68A it's a simple operation and they index off the cranks and cam centerlines for parallel to the crank, and have the perfectly-perpendicular-to-base 1.5" thick end plate. Errors in timing cover and bellhousing machinging are just as common as deck height, mains, and lifter bore issues. A good shop (nevermind a great shop) will have equipment that can do this easily. IMO an "average" shop should be avoided unless you have better than "average" luck.
[Re: moper]
#1392860
04/29/13 02:56 PM
04/29/13 02:56 PM
JohnRR
U.S.S.A.
Just had this done in a Rottler 69 , block was originally done in a CNC , I assume Rottler ??? the bellhousing surface was off .012 on my 69 383 HP block.
Guess I could have just used a soda can to fix that
