Where to buy 72 D100 seat covers? #1388891
02/17/13 12:26 AM
02/17/13 12:26 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
The original seat covers in our 72 D100 are getting pretty tired. It needs to be re-covered before the foam starts to deteriorate. Where are you guys getting your stock replacement seat covers for this era of truck?
Thank you for any advice you may have.
Re: Where to buy 72 D100 seat covers? [Re: Jeremiah] #1388892
02/17/13 12:48 AM
02/17/13 12:48 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I plan to try a guy from work. He charges $300
If he does a good enough job Ill use him for others. Ive seen a company in a hotrod mag that has tons of covers. Otherwise I only know a local shop will charge around $300+ for just a cover that you install if they can even order one to specs. Probably not much help
