more 8 lug q's #1387175
02/14/13 01:47 AM
02/14/13 01:47 AM
utah
jjl Offline OP
jjl  Offline OP
utah
Do they make 8 lug rims in 15 inch.If I get this 3/4 ton I want to swap my 35's to that truck.They are on a half ton now.
formally orangemonster
Re: more 8 lug q's [Re: jjl] #1387176
02/14/13 02:49 AM
02/14/13 02:49 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Yes they do, but sellection is very limited.
Possibly only white spoke. And you will need to double check the hub center diameter. They used to be popular on Chevy trucks, so I don't know if the hub center was sized accordingly.
Also before you spend the cash, take some measurements, the 15" 8 lug were popular when front axles still used drum or small rotor front brakes. They may not fit on a "newer" 3/4 ton with a factory 16" or larger wheel.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: more 8 lug q's [Re: hp383] #1387177
02/14/13 02:52 AM
02/14/13 02:52 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Re: more 8 lug q's [Re: jjl] #1387178
02/14/13 05:13 AM
02/14/13 05:13 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Everything I've seen and heard the caliper needs some grinding for clearancing. Possibly the drums in the rear aswell. I beleave they run very little backspacing to help clear also. You'd almost be better off getting the rite size tires for the truck. Sell your 15s to help fund them.
Re: more 8 lug q's [Re: 76dodgeboy] #1387179
02/14/13 10:27 PM
02/14/13 10:27 PM
utah
jjl Offline OP
jjl  Offline OP
utah
Thanks for the replies,now that you have said the calipers are close,my old 78 had 16's with cast rims and they were very close.Got some thinking to do.
