Re: Engine Knocking [Re: buildanother] #1386798
02/15/13 01:29 PM
02/15/13 01:29 PM
dogdays Offline
dogdays  Offline
Huh? Please explain how putting a vacuum nozzle in the spark plug hole, or near to it, is going to cause the dirt around the hole to go into the cylinder. I don't see any laws of physics there. And if the intake valve is open while you do this, the cylinder will have filtered air coming into it while you vacuum out anything that may be in there that can fit through the sparkplug hole.
R.
Re: Engine Knocking [Re: dogdays] #1386799
02/15/13 03:09 PM
02/15/13 03:09 PM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Try it sometime! (actually don't!) When you put a vacuum hose up to the spark plug hole you are actually creating a greater negative air pressure inside the cylinder (especially with the valves closed), thus sucking whatever dust,dirt etc around the spark plug hole right into the cylinder. Air filter? That does provide a slight restriction, so air is gonna come from path of least resistance.
When you take a air gun with a longer nozzle and put it in the plug hole and blow compressed air in the cylinder the pressurized air excapes the plug hole and blows out the dust/dirt away from the plug hole.
Same thing goes for when you pull axle shafts and you want to get the sand/dirt out of the axle tube. Use a vacuum cleaner and you'll pull all that stuff right into your differential. I guarantee it.
-J
Re: Engine Knocking [Re: hp383] #1386800
02/15/13 07:20 PM
02/15/13 07:20 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
to much of any solid liquid will hydro lock it so go slow adding it in.
OK so no ice down the carb then...
what about jello?
Re: Engine Knocking [Re: Golden-Arm] #1386801
02/15/13 08:19 PM
02/15/13 08:19 PM
scratchnfotraction Offline
what about jello?
only as a liquid not a solid.
quadrajet cause I said too?? dont forget the 2.76 gear with it.
I like my roller cam 318,but I have drove the 440 truck 80 miles a day x5 to work/home this week getting 13 mpg. right now it is worth the extra cash just to finaly enjoy it after 4yrs of hard work,setbacks,re-direction,disapointments,priortys,$$$$,ect...
life is to short not to.
Re: Engine Knocking [Re: scratchnfotraction] #1386802
02/15/13 08:54 PM
02/15/13 08:54 PM
Maine
P
Pkeel Offline OP
Pkeel  Offline OP
P
Maine
That's the spirit. Build it to use it. The 80 gets 8 miles a gallon right now. That's about 50 cents a mile! It will be driven this summer.
Re: Engine Knocking [Re: Pkeel] #1386803
02/26/13 09:11 AM
02/26/13 09:11 AM
Maine
P
Pkeel Offline OP
Pkeel  Offline OP
P
Maine
Finally had a decent enough day to look at the truck again.
Started it up... no Knocking. ?
We put some sea foam through the system anyway, but there was no knocking when we started it up. Was it a stuck lifter? That is my guess at the moment.
Re: Engine Knocking [Re: Pkeel] #1386804
02/26/13 09:48 AM
02/26/13 09:48 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Most likely...or maybe a stuck valve that freed itself up. In any case, drive it!
