Re: Small Block Timing Question
[Re: Hey19]
#1381798
02/05/13 09:31 AM
02/05/13 09:31 AM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Most of the small block strokers are running low 30's I run mine at 32* They apparently don't like a lot of timing. You said you run 1/8 mile then posted times in the 11's, I have to assume those are 1/4 times?
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: Hey19]
#1381800
02/05/13 10:32 AM
02/05/13 10:32 AM
Posts: 1,178 Indy
FlyFish
Indy
........It runs 11.01-02 at 97 and I just can't squeeze the 10's out of it.....
I'm assuming it runs 7.01-02 @ 97mph
My car has almost the exact same setup, only my cam is a roller (248/254 duration, .576/.584 lift). Mine likes 34°. You are very close, probably making power fine, possibly the suspension or converter holding it back...speaking of, what do you have for suspension and converter? 60' times would help too.
For a frame of reference, my 67 Barracuda runs low 6.9's in the 1/8 in the heat of the summer. Current best in sig.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Hey19]
#1381801
02/05/13 11:00 AM
02/05/13 11:00 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The efficiency of the head and the fuel used determines what the timing should be... the better the head the lower the timing will be but for most its in the 34* range
[Re: Hey19]
#1381803
02/05/13 12:58 PM
02/05/13 12:58 PM
Posts: 7,506 Az
Crizila
Az
If you can knock another .05 off your 60 foot times you will be there.
Fastest 300
[Re: Crizila]
#1381805
02/05/13 06:42 PM
02/05/13 06:42 PM
MR_P_BODY
...start looking at the chassis... get the front end loose.. and watch your rear shock adjustments
[Re: MR_P_BODY]
#1381806
02/05/13 09:43 PM
02/05/13 09:43 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
put smaller jets in the carb. Keep going until the car loses MPH. Then go up two numbers.
Same thing with timing keep dailing it up til it slows down then go back two numbers.
I can't say this enough MPH is HP. ET is not. Get your MPH by tuning the engine. Then work on the suspension to get the best short times. If footbraking you can play with squirters and timing curves.
Leon
[Re: Hey19]
#1381807
02/06/13 11:24 AM
02/06/13 11:24 AM
Posts: 1,178 Indy
FlyFish
Indy
Yea I was thinking and typing (not good). The car averages 7.1 at 97 in the 1/8th. It has run 11.01 on the quarter. It has 28-10.5 slicks, 4.56 gears, super stock springs, 904 SMR trans foot brake, and a 4300 stall converter. It has ported edelbrock heads on it. 60 ft times are 1.59. Thanks for the input I will check and run 32-34. I would like to get it to run in the high 6's consistently.
Yeah, I would work on the suspension. My car has the same size tire (Hoosier QTP street slick) and 4.10 gears with a 727 trans with a 8" converter (5000 stall). Even when I had stock springs (not super stock) the car would 60' between 1.49 and 1.53....Do you have 90/10 drag shocks on the front? If not, get some. Also, if you want to help the weight transfer, move the battery to the trunk (if you have not already done so). My other "trick" is to pull the front bumper and brackets off. It takes less than 3 minutes to remove, and only about 5 minutes to put back when you are done...just 4 bolts, 3 minutes of your time and it shaves 33 lbs off the nose of the car...that right there would probably get you that 6 second time slip. Good luck
