Re: fresh air door helper spring on e-body a/c heater box
[Re: walkAbout]
#1381043
02/11/13 06:25 PM
02/11/13 06:25 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
bump... All boxes built in currently?
TIA Thomas
I can't tell you exactly where it goes as it is not a totally exact science and I don't have my box out. What I can tell you is it helps a lot if you rivet a 1/16" piece of sheet metal on the outside of the box there to prevent the hole from ovaling out.
This is what happened on my Charger's box and the helper spring was getting stuck because of the ovaled hole. I mean, it just plastic so it's gonna happen. I riveted on the sheet metal, drilled it and ground a small circle around the hole for the spring to rotate in and that fixed it. If yours is broken here, you may consider doing this.
That spring gets under a good amount of tension and will pull itself through a glue repair pretty easily.
Just my two cents
[Re: cjskotni]
#1381044
02/12/13 04:46 PM
02/12/13 04:46 PM
Posts: 35 Germany
walkAbout
Germany
...What I can tell you is it helps a lot if you rivet a 1/16" piece of sheet metal on the outside of the box there to prevent the hole from ovaling out.
Many thanks for enlighten me. I would see that in a couple years, otherwise.
Really good upgrade to the original box, I will do that definitely too.
Now let's find, where the hole goes, I think I will ask DMT directly.
CU
walkAbout
[Re: walkAbout]
#1381045
02/13/13 08:48 PM
02/13/13 08:48 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
I just make the foam pieces I can see if I have pieces from an old E A/C heater box at the shop to get measurements from. Jim
[Re: 71TA]
#1381046
02/14/13 03:36 PM
02/14/13 03:36 PM
Posts: 35 Germany
walkAbout
Germany
Hi Jim,
yeah, I got my foam pieces from you (DMT), and the pic above is from your foam resto guide. You delivered to CA last summer, when I was there. Just wrote an email to Loretta 1-2 days ago, as I have the email address from paypal.
Thanks for looking. Thomas
[Re: walkAbout]
#1381047
03/11/13 06:19 PM
03/11/13 06:19 PM
Posts: 35 Germany
walkAbout
Germany
Could anyone measure it? Still not drilled, as I have to produce the metal, where the hole goes into... TIA Thomas
