window trim clip studs #1379838
02/01/13 02:38 PM
02/01/13 02:38 PM
St. John's Newfoundland
440newport Offline OP
My 80 Mirada is missing some of the studs that hold the window trim clips on around the windshield, While I have the windshield out I wanted to fix it.
Can you buy these new? Do they have to be welded on, or are they a type of rivet?
I suppose i could use small screws but I'd rather do it the right way if possible.
Re: window trim clip studs [Re: 440newport] #1379839
02/01/13 04:11 PM
02/01/13 04:11 PM
Chilly Northern, Minn.
71 Charger R/T Offline
The "right way" is to use a "uni-spotter" or equivalent type stud gun with the mold rivets. I used this method to install the mold rivets for my Landau molding on my roof........no holes to let water in and rust.
Re: window trim clip studs [Re: 71 Charger R/T] #1379840
02/02/13 11:22 AM
02/02/13 11:22 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
contact a auveco fastener dealer, most auto body shop supply stores, and get replacement screw studs, they only sell in a box of 100.
https://www.auveco.com/eSource/ecom/eSou...mp;bulkexists=1
$10 a box on ebay http://www.ebay.com/itm/100-4-24-X-3-8-Z...502&vxp=mtr
perception is 90% of reality
Re: window trim clip studs [Re: Mr T2U] #1379841
02/02/13 02:16 PM
02/02/13 02:16 PM
I'll see if I can find anywhere in town to rent the stud welder. If not, I'll go for the screws.
