Page 3 of 3 1 2 3
Re: A-833 overdrive won't shift 543 stroker [Re: Shawnb] #1379164
02/03/13 03:59 AM
02/03/13 03:59 AM
Cab_Burge Online work
Cab_Burge  Online Work
Change the fluid to ATF and adjust the clutch as suggested, NO JOKE Been there, done that You will be amazed with the results
Re: A-833 overdrive won't shift 543 stroker [Re: Cab_Burge] #1379165
02/03/13 12:20 PM
02/03/13 12:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dude, if up shifting and down shifting are difficult, especially when not speed shifting you have issues that are not related to the power output.
When I set up my last A833, rebuilt it myself, I could up and downshift without a clutch, gear oil in trans not ATF either. I could speed shift the thing like no other trans I ever had.
Don't be the exception.
Page 3 of 3 1 2 3
