Re: What are the downsides of body lifts?
[Re: dhkennedy]
#1378982
01/31/13 10:44 AM
01/31/13 10:44 AM
Posts: 15,487 Florida
scratchnfotraction
IMHO, leave it on stock mounts and do a spring lift with steer gear mods/upgrades. I had 3" lifts on a few,always shifting troubles, mounts come loose when off roading,ect... I like a 6" lift with 17/40/15 ground hawgs,I used a droped pitman arm,raised steering arm,adjustable dog bone. swamper 39.5 are nice. best all around was the 14/35/15 hawgs with the 6" lift. I used 12" springs in the rear to ditch the stock block with the lift block in the lift kit. you could do a 4" front spring with the shackle flip in the rear for a cheap lift to fit 35s body lifts are like open diffs,they work but not like you need them to.
[Re: scratchnfotraction]
#1378983
01/31/13 09:40 PM
01/31/13 09:40 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Maybe this body lift kit is worth what I paid for it. A guy GAVE it to me.
[Re: Kern Dog]
#1378985
01/31/13 10:31 PM
01/31/13 10:31 PM
scratchnfotraction
yep,for sure I would use the springs with no body lift on that brute.
some 12" wide 4.5 bs rims,17/40s,6" lift with the nose slightly up,440 granny trany full time with 4.56/locker in the rear.
I would be putting a part time kit in the xfer with a set of happy hookers for 2x scratchin with just the 4.56 spining the locker in low range 3rd gear
have you invested in a 5 gallon pail pump yet??
comes in handy with 2 axles and granny tranny/exfer. dont you have 2 4x4s now? remember,the lowest bolt on front output shaft rear cover drians ALL of the xfer lube when you service it.
[Re: NITROUSN]
#1378989
02/01/13 04:21 PM
02/01/13 04:21 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've seen people use drilled out hockey pucks for body lifts I always thought body lifts looked bad because of the bumper gap and so on.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 76440]
#1378993
02/02/13 12:07 AM
02/02/13 12:07 AM
Kern Dog
Granite Bay CA
Did the guy ad the ramcharger macho tape stripe to the gate? Or is originally off a 77-78 orange macho ramcharger?
Bob added that stripe. I like it, but it will get removed when I repaint the truck this summer.
