Should there be a ballast resistor on the coil? #1378747
01/30/13 07:26 PM
01/30/13 07:26 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
('85 Dodge ram 150, 318 engine, 2 bbl holley carb)
I changed out the coil on my truck last weekend, didn't notice a ballast resistor anywhere around the coil.
I alaways thought Mopars used ballast resistors?
Re: Should there be a ballast resistor on the coil? [Re: rnch] #1378748
01/30/13 07:48 PM
01/30/13 07:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The ballast resistor is on ther firewall not the coil. Good sized white ceramic block.
Re: Should there be a ballast resistor on the coil? [Re: stumpy] #1378749
01/30/13 07:57 PM
01/30/13 07:57 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Well, NO WONDER I didn't see it by the coil!
Re: Should there be a ballast resistor on the coil? [Re: stumpy] #1378750
01/30/13 08:01 PM
01/30/13 08:01 PM
scratchnfotraction Offline
the small BR looking doodad mounted by the coil is the choke heater relay/BR something or other.. for the choke pull off.
the BR is on the firewall over by the steering colum.
sometimes a coil will have a radio noise superssion condenser looking thing wired on with the coil wires.
unless you need to pass emissions test,i would swap on a small 4-v carb and do the points dist with a pertronix points conversion with one of their flamethrowwer 40,000 volt coils.
then by-pass the BR for full 12 volts to coil.
best thing I did on my 85 stepside. i do it on all my mopars. striped all the wire not need from the 88-440 truck.
got rid of all this mess under hood.
Re: Should there be a ballast resistor on the coil? [Re: scratchnfotraction] #1378751
01/30/13 08:05 PM
01/30/13 08:05 PM
this looks much cleaner and never a problem after it is converted to a pertronix set up.
I just set up a mallory mech duel point dist with a pertronix conversion for the 440 engine.
Re: Should there be a ballast resistor on the coil? [Re: scratchnfotraction] #1378752
01/30/13 11:47 PM
01/30/13 11:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
White thing to the passenger side of the brake booster.
Re: Should there be a ballast resistor on the coil? [Re: stumpy] #1378753
01/31/13 10:29 AM
01/31/13 10:29 AM
stumpy,has that BR been placed in that spot or was it there stock?
mine is over by the steer colum. but seems I recall them in different spots.
I worked on one that had the VR by the BATT on the fender not the firewall.
Re: Should there be a ballast resistor on the coil? [Re: scratchnfotraction] #1378754
01/31/13 01:42 PM
01/31/13 01:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's my first 85 so I'm not sure but it looked stock other than the replaced wires.
Re: Should there be a ballast resistor on the coil? [Re: stumpy] #1378755
01/31/13 04:00 PM
01/31/13 04:00 PM
MO
C_Notch Offline
C_Notch  Offline
MO
Is there anyway to do away with the ballast resistor?
Re: Should there be a ballast resistor on the coil? [Re: C_Notch] #1378756
01/31/13 05:12 PM
01/31/13 05:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pertronix or some other replacement distributor and coil setup
Re: Should there be a ballast resistor on the coil? [Re: stumpy] #1378757
01/31/13 08:57 PM
01/31/13 08:57 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I found the ballast resistor on my '85 Ram.
It's located on the firewall, on the extreme left (driver's side), between the steering collum and the front fender.
It was staring at me the whole time.
Re: Should there be a ballast resistor on the coil? [Re: rnch] #1378758
02/01/13 05:34 PM
02/01/13 05:34 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
Why are there some ballast resistors with 4 terminals?
What are the other 2 terminals used for??
