Manual brakes Question
#1376828
01/27/13 12:07 AM
01/27/13 12:07 AM
Posts: 3,449 Gateway to the West.
hemi_harvester
I have a 87 Ramcharger, I want to convert to manual brakes, my question is on the trucks is there a firewall reinforcent plate when you have manual brakes like on a B body car ? or does the master cyclinder bolt stright to the firewall?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Manual brakes Question
[Re: hemi_harvester]
#1376829
01/27/13 06:31 AM
01/27/13 06:31 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Not sure but I believe theres a plate for the master to bolt on to the firewall in place of the booster. What do you have against power beraks? Power brakse replaced manual brakes for a reason...
I am truckless..
[Re: 340SHORTY]
#1376830
01/27/13 12:00 PM
01/27/13 12:00 PM
hemi_harvester
I'm going to put in a Big Block and need the room plus I'm changing the cam so vacuum will also be a issue.
#1376831
01/27/13 12:10 PM
01/27/13 12:10 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
With an appropriately sized master cylinder, manual brakes can be nice, provide much better "feel" of brake modulation, and offers a cleaner engine bay without a booster and hoses for vacuum
**Photobucket sucks**
#1376833
01/27/13 12:57 PM
01/27/13 12:57 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
What size big block? B Blocks will fit with all brake setups. RB Blocks Need the small booster. That's what vacuum canisters and pumps are for. I do know there's a plate as the bolt pattern is diff bit don't believe is not really reinforcement
[Re: coronet1966d]
#1376836
01/27/13 10:36 PM
01/27/13 10:36 PM
Posts: 15,487 Florida
scratchnfotraction
remove the vac booster and use the foam gasket as a template to make a metal plate drilled for a 2 bolt alum MC the manaul brake rod is 7" long and you can get the adjustable brake rod. all I did was order up a MC for a 79 ramcharger,used the stock prop valve,with 11x2.5 rear drums,large wheel cyls. spoon up the rears and it has a nice firm pedle and stops great with the 440 up front on my 88 truck. here is a stock rod and plate from a manual brake truck,this is the set up I gave to John.
