Page 9 of 12 1 2 7 8 9 10 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376704
02/18/13 07:18 PM
02/18/13 07:18 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I better just put this on hold until I have the money for the HP Tuner because the cheapest local shop I called today was $550 for a speed density tune on the dyno. I can buy the VCM suite for $500 with 8 credits and tune on the street..err I mean track. I'm starting to like my carburetor more and more
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376705
02/18/13 08:22 PM
02/18/13 08:22 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
Also...stay away from the handheld powertuners and such...they don't have the capabilities that you will need to make this kind of swap work....like turn off VAT's (some will), change firing order bank assignments, etc.
HPtuners or EFI Live (more $$) are the only ones with the capabilities we need.
But I can also use the HPtuners to tune/diagnose problems on my 6.0 Suburban too...
Or you could look for a used HPtuners...to save any more money....just make sure there are credits left on it...or that it's really cheap. make sure it's the newest version though...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376706
02/18/13 08:36 PM
02/18/13 08:36 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
And one more time from a guy who's worked on allot of Fuel Injection... My vote is a OE PCM because they have diagnostic capabilities including freeze frame PID recording & trouble codes.. With aftermarket systems you need your laptop hooked up & you need to be viewing the proper parameters if & when something goes wrong... Hard faults are easy, intermittents can be challenging but if you've go an OE PCM it will detect a fault, set a code & record the data just prior to, during & after the event....
It looks like MS3X Does all this as well, I can set parameter for "Check engine light" and the MS does real time logging non stop anyhow for as big as the card inserted is.
Plugging in a laptop is no different to me then plugging in an OBDII scanner except with the MS I get real data instead of just a trouble code.
I guess the LS tuning software does something similar??
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376707
02/18/13 10:19 PM
02/18/13 10:19 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I grabbed my LS1 harness from a 1999 F body @ My work about two years ago waiting to do the same to my R3 engine. I would also like a Sb spacer also if you get time to whittle more up, just p/m me when you have one!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376708
02/18/13 10:37 PM
02/18/13 10:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
OBDII and even some OBDI systems would do real time data, What OBDII systems do is constantly log data saving about a five minute recording, dumping old data & saving the most recent... Then if a fault code is generated the PCM stores that data till it is manually deleted.... And goes back to recording waiting for any future failure... This data can all be accessed with a scan tool plus you can view live data..
It's good to hear one of the aftermarket companies is making an effort to help on the diagnostic side.... The OEM's have a much bigger budget & allot of very sharp engineers for developing a engine control package.. Most aftermarkets have a limited budget, one or two very sharp engineers with lots of passion for their product & hopefully a willingness to provide the highest quality components available.. But it's hard to compete with the OEM's years of experience & unlimited testing budget...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376709
02/18/13 11:32 PM
02/18/13 11:32 PM
Central Valley, CA.
Central Valley, CA.
Sounds like MS3X has much of the same capabilities...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Dos Snails] #1376710
02/18/13 11:32 PM
02/18/13 11:32 PM
Central Valley, CA.
Central Valley, CA.
Sweet!!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376711
02/19/13 12:08 AM
02/19/13 12:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am curious if any of these aftermarket units can record data that you can play back. I retired from Chrysler in early 2011 but from 1992 on up I could record data and then play it back in the bigger shop computer. I could set the trigger to go of from a code or manually by pushing the button. And when it acted up you would push the trigger and it would record 45 seconds before you hit it and 10 seconds more after hitting the trigger. That way if it had a glitch and you did not hit the button until 15 seconds later you would still get the recording. Funny thing was I was the only tech in my dealer who learned how to use it and I loved it. Had a Caravan that would drop cylinders about 45 mph that drove me nuts until I took a recording and saw the speed sensor was going crazy telling the PCM it was going as fast as 504 mph ! Course the PCM was speed rated to drop cylinders an 108 mph. These aftermarket units sound like they are pretty smart from what I hear but I have never fooled with one. Ron
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 383man] #1376712
02/19/13 08:52 PM
02/19/13 08:52 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Yes, MS3X Will record real time data to include your own voice making comments over the data as you go down the track. You can even tune the engine via bluetooth realtime if you want.
The thing about MS3X is it has unlimited budget since it's open source. heck, people are flushing ipads in the dashes of there cars and using the MS3X as a gauge cluster. That can see real time, logged, and tune the car off a single touch screen in the dash. Then you can watch a movie or play music I guess, haha
On top of that, you get programmable outputs, Launch control, soft, fuel, and spark limiters, 3 stages of nitrous control, it goes on and on and on!!
The tuning software is $40 for the good stuff, and it has a self learning feature built in.
This guy has a bunch of stuff graphed real time on a screen in his van, haha
https://www.youtube.com/watch?v=j0RLx8UPS8w
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376713
02/19/13 09:51 PM
02/19/13 09:51 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Sweet!!
love this post.
I am surprised not to see the "It's not a MOPAR part bla bla bla........."
to you for figuring out a system to run your Mopar engine. I brought this up in another post a long time ago stating that Fiat should give up their encryption software to help out hot rodders.
It would be nice to use a factory Mopar ECM to run your Mopar engine.
Now for the real question. Drive by wire on an G3 Hemi does the ECM pick up the signal from the pedal AND throttle? Or is it just from the throttle? Is it posible to fab a mechanical cable to the throttle to get rid of the pedal?
Thanks for the great write up
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376714
02/24/13 03:12 AM
02/24/13 03:12 AM
Clovis, Ca
Burlapen Offline
Burlapen  Offline
Clovis, Ca
I think I have read through the entire thread but I am still a little unsure on exactly what it takes to make this swap happen. Basically the main hangup is the cam sensor correct which is what all this custom machining is about, right?
Rob- Im in Central CA also. I have a complete 5.3 with harness and computer which I was going to use on another project but have since changed directions. So Im looking at this LS on the stand and the 440 in my satellite and thinking I can make this injection swap happen. I also have some spare coil packs and LS odds and ends if you need some.
Great thread
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Burlapen] #1376715
02/24/13 03:59 AM
02/24/13 03:59 AM
Central Valley, CA.
Central Valley, CA.
The main issues are to get crank and cam sensor signals to the PCM....both can be accomplished as shown in this thread (there are 2 ways shown to get a cam signal).
The next issue is the wiring harness stripped down to a stand alone harness to get rid of 2/3rds of those unneeded wires, etc. You can follow many of the online guides to do this....but just switch the wires at the PCM for the change in the firing order. Other than that...it's mostly basic LS fuel injection tuning.
I'm just a few hours south of you .
I appreciate the parts offer...I'll let you know if anything comes up...probably wont need any though since mines almost done.
I gotta get the pinout diagram finished....
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376716
02/24/13 04:35 AM
02/24/13 04:35 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
just got done reading this again sounds like something i would want to do to my car. but sorry if i missed it but how hard would this be to make work on my two for tunnel-ram. also wasn't you going to maybe offer this in a kit some way? don't really have the money to do it right now but latter on down the road i would like to do it to my car. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376717
02/24/13 04:37 AM
02/24/13 04:37 AM
DFW Texas
gearheads78 Offline
gearheads78  Offline
DFW Texas
Thanks for sharing this. I have had this idea to use on an Olds project for a while just never seen it done.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: mopar65] #1376718
02/24/13 05:16 AM
02/24/13 05:16 AM
Central Valley, CA.
Central Valley, CA.
Really no different on a tunnel ram....just add bungs to your manifold (can even be done with JB weld epoxy if you don't want to TIG them). You just have 2 Throttle bodies and just use the TPS and IAC on one of them.
I had originally thought about making the Crank and Cam sensor setups to sell, and the wiring harnesses. Don't know if I ever will do that or not....but I decided to just share what I've learned for now.
Maybe Redmist will make a batch of the cam sensor bushings to sell...that would make the swap easier too.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376719
03/02/13 08:46 PM
03/02/13 08:46 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I have to say your quite resourceful Quicksilver!
Another crank sensor/trigger option if a damper with the 3 bolt GM pattern on front is used would be the Big Stuff 3 24 tooth wheel.
The OE LS1 computer and coils are good to 8000+ rpm. The tables in the HP Tuners software may stop at 8000 rpm, but the values maintain themselves at the 8000 rpm setting (flatline) when that rpm is exceeded.
Good Luck with your project, and please keep updating as you go.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: LSP] #1376720
03/03/13 03:13 PM
03/03/13 03:13 PM
Central Valley, CA.
Central Valley, CA.
Thanks man!
If your talking about this wheel:
The one shown won't work with the LS PCM....the LS 24X reluctor has a very unique tooth pattern. Or is there a different one made by BS3? I tried googling it..but thats all I found. It is 24X...but the wrong pattern for the LS PCM.
The LS PCM can definitly handle most engines needs...my brothers shop has several LS based cars (using stock LS PCM's) in the 8's. and he's building one that will hopefully be in the high 7's as his personal car.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376721
03/03/13 09:18 PM
03/03/13 09:18 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I just ordered the 24x for the BBC to adapt to the SBM. I just have to find where the keyway goes & Tig it to the front crank gear or slinger plate..
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376722
03/04/13 11:29 PM
03/04/13 11:29 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Ok, two questions. how did you figure where #1 is on the 24x wheel & you are running two wheel sensors @ 27 degrees apart ?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Dos Snails] #1376723
03/05/13 05:46 PM
03/05/13 05:46 PM
Central Valley, CA.
Central Valley, CA.
I'm just running one OEM crank reluctor (which essential is 2 wheel patterns riveted together...which produces one signal)...and one sensor.
Here is a pic showing when TDC#1 is located:
