#1376404 - 01/26/13 01:29 PM 1984 W150 4x4 front end assembly question (snap ring)
hulmule Offline
Loc: northeast ohio
Bought this 1984 4x4 1/2 ton to fix up. Came with a box of parts ,cause they started to tear apart the front hubs. Someone at one time, put on M@M lock outs on it. Well everything is in pieces,found one snap that is bent up and missing one for the other side.Went to all auto parts stores and tractor supply , found a couple that are close but not really correct.The original snap ring is thick and solid and the replacement ones are thinner and cheezey.Worried about it not hold the assembly together correctly. Besides trying to find something in a junk yard that old and not damaged where can i get two?? would really like to get this front end back together. Any dodge web site that shows this break down and call out the size and thickness of this snap ring?? Thanks !
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
#1376405 - 01/26/13 04:11 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule]
76dodgeboy Offline
Loc: Iowa
Buy New
"MOPAR" its a lifestyle"
#1376406 - 01/26/13 07:38 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy]
hulmule Offline
Loc: northeast ohio
love to buy new !! but where??
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
#1376407 - 01/26/13 07:53 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule]
68shifter Offline
Loc: MI
I think he's referring to new lockouts. You can get warn and mile marker for less than $100. Otherwise try a true nut/bolt supplier. They typically stock more odd size stuff. Local 4WD and driveline shops should be able to help too.
#1376408 - 01/26/13 08:22 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 68shifter]
hulmule Offline
Loc: northeast ohio
wow $100 for 2 snap rings!! maybe i can call M&M and buy 2 snap rings. I think it was the stock hubs that used them
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
#1376409 - 01/26/13 08:25 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule]
76dodgeboy Offline
Loc: Iowa
No $100 for the Lockouts
#1376410 - 01/26/13 08:40 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy]
hulmule Offline
Loc: northeast ohio
So i have a extra set of lock out laying around just missing the snap rings LOL
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
#1376411 - 01/26/13 09:19 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule]
NITROUSN Offline
Loc: UPPER MICHIGAN, MARQUETTE COUN...
Some aftermarket hubs do not use a snap ring on the axle shaft. Be sure so find the install instructions for the hubs you intend to use.
#1376412 - 01/27/13 12:14 AM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: NITROUSN]
76dodgeboy Offline
Loc: Iowa
Here's a thought call the company that makes your current Lockouts and get the parts you need
#1376413 - 01/27/13 01:42 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy]
hulmule Offline
Loc: northeast ohio
Been on line looking at the company. looking for a parts list but they dont seem to show any.got a email into them already.- Trust me im on it! trying to cover all my bases as i move forward.i like coming to moparts and ask cause i hate to wait for answers from customer service.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
#1376414 - 01/27/13 01:53 PM Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 68shifter]
basketcase Offline
Loc: east side of Ohio
4 Wheel Drive Hardware, Columbiana,Ohio
330-482-4733
1969 Plymouth road runner post 383 4 speed F8
1981 Dodge D150 360 auto
25,738 Registered Members
192,835 Topics
1971 HEMICUDA HISTORY SEARCHING.. BS23R1B CAR
by 71redcuda
02/16/19 03:46 AM
6.4 BGE block
by HOTMOPR
02/16/19 12:11 AM
Couple Pertronix questions....
by gss
02/15/19 11:00 PM
Adopt a pet
by Superfreak
02/15/19 10:43 PM
