Brake pedal not releasing on LRT #1376321
01/26/13 11:26 AM
01/26/13 11:26 AM
RI Deep in the rust belt
chargervert Offline OP
My 78 LRT has been sitting on the side of my garage for the last seven years. I got it running again out of a gas can,and I bought an electric fuel pump to pump the bad gas out of the tank. I moved it and the brake pedal is not fully releasing when I take my foot off the brakes. I figured it may be the brake hoses or stuck calipers,so I replaced the hoses,calipers and brake pads. The brake pedal is still not releasing,do you guys think it's the master cylnder,the brake booster,or both?
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376322
01/26/13 12:03 PM
01/26/13 12:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Booster being bad will cause the pedal to not come back up. Wouldn't hurt to replace mc and booster
Re: Brake pedal not releasing on LRT [Re: 76dodgeboy] #1376323
01/26/13 03:45 PM
01/26/13 03:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376324
01/27/13 10:32 AM
01/27/13 10:32 AM
Adventurer_Sport Offline
It's likely nothing more than the shaft needing fresh lube.
It's nearly impossible to lube from the ends of the bushing and I had to disassemble mine to clean out the old, dried residue from the bushing. Fresh lube...like new.
Re: Brake pedal not releasing on LRT [Re: Adventurer_Sport] #1376325
01/27/13 01:03 PM
01/27/13 01:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wife 76 wouldn't bring the pedal back up and it was Bad Booster.
Sometimes a bad booster will also produce a hissing sound. My Crewcab currently needs booster. Hisses
Re: Brake pedal not releasing on LRT [Re: 76dodgeboy] #1376326
01/28/13 12:04 AM
01/28/13 12:04 AM
Who has the best deals on brake boosters for a 78 LRT?
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376327
01/28/13 12:42 AM
01/28/13 12:42 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
My 80 had the same problem, I ended up buying a new booster...but that was not the problem. I found that the shaft that the pedal is attached to was rusty and needed lube, I should have checked it first before buying a new booster.
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376328
01/28/13 03:57 AM
01/28/13 03:57 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Just because its on a LRT it just the same booster as any other Dodge truck of that year..
I am truckless..
Re: Brake pedal not releasing on LRT [Re: 340SHORTY] #1376329
01/30/13 12:12 AM
01/30/13 12:12 AM
I know that it takes the same booster as any other power disc brake equipped 78 Dodge truck. Where is the best place to locate/purchase one?
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376330
01/30/13 12:15 AM
01/30/13 12:15 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I bought my last setup from Rockauto
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Brake pedal not releasing on LRT [Re: chargervert] #1376331
01/30/13 04:21 AM
01/30/13 04:21 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
No it don't. There's more than one style available. Any and ALL Parts stores can get it as just the booster or booster/master cylinder combo.
