Re: Triple Black Bee
[Re: OhioMopar]
#1375980
07/20/13 07:42 PM
07/20/13 07:42 PM
Posts: 5,302 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Nice car Darin Keep plugging along at it, to make it driveable... I wanna see that car in the Donut Cutter parking lot on Wednesday night...the week of the Dream Cruise.
Plymouth Makes It!
[Re: OhioMopar]
#1375983
07/23/13 09:31 AM
07/23/13 09:31 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
More progress. Last night was very frustrating because the simple fact is that I'm not as nimble as I used to be. One nut on the master cylinder was driving me crazy. So I took a break to install the disks. Also ran into some issues there. Front mounted calipers and the caliper bracket hits the sway bar tab. Rear mounted the caliper hits the shock. And the hose routing is a little suspect. I also really need to replace the front shocks. The front suspension wouldn't compress with a jack under it. Anyway, still made progress. I'll put another coat of primer on the engine, and hit it with color in the next couple days. Old master cylinder gone. New spindle. Won't work thatway.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: new bee]
#1375987
07/23/13 08:05 PM
07/23/13 08:05 PM
Posts: 98 Md
EK2Runner
Md
Looking good . It'll be a nice/fun ride when completed Mike
It's a Mopar thing , If you have to ask you wouldn't understand
[Re: EK2Runner]
#1375988
07/25/13 09:38 AM
07/25/13 09:38 AM
OhioMopar
Mt.Gilead, Ohio
More progress. Brakes are installed. Tonight I'll tighten, torque and bleed them. Lines are run. I need to flush the distribution block with some brake clean and reinstall it. Engine is now orange. Another coat and I'll start installing accessories. Hopefully Friday night it will be ready to drop in. Gas tank is in and needs tightened and rubber hose run, vent lines installed and I need to clean the filler neck real well and reinstall it. It's getting there.
[Re: OhioMopar]
#1375989
07/25/13 10:34 AM
07/25/13 10:34 AM
OhioMopar
Mt.Gilead, Ohio
Left side: Right side: Engine bay has all the pretty lines now:
[Re: OhioMopar]
#1375992
07/25/13 01:09 PM
07/25/13 01:09 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
not waisting anytime are you? hey what are you doing with your stock spindles? a buddy of mine needs one and hasn't had any luck finding one.
1981 Dodge D150 360 auto
[Re: 70440+6bbl]
#1375993
07/26/13 03:23 AM
07/26/13 03:23 AM
Posts: 6,301 colorado
a12superbee
colorado
Yep, you'll be wheeling the neighborhood in no time. Amazing how much your car looks like mine all the way down to the rust and crust. Only difference when I got it was the ramcharger scoops were white.
