Re: Triple Black Bee
[Re: OhioMopar]
#1376094
09/19/13 04:03 PM
09/19/13 04:03 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
It's gonna look that way for a while. I don't have a $50K car fund, either. working on that running thing, too...
Strive to endeavor...
Blood, sweat, and tears keeps you honest...
[Re: RSNOMO]
#1376097
09/19/13 09:47 PM
09/19/13 09:47 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Well, I got the brakes figured out and will get the parts I need to finish it tomorrow. I will also pick up an adjustable timing light to set the timing on it. I finished the distributor tonight, too. Put a set of Mopar light advance springs in it. I got the new rear tires mounted and a buddy came over and helped me get the hood on and adjusted pretty close to right. I'll get the brakes finished, again, tomorrow and I hope to pick up an exhaust system, then it is time for some road miles!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#1376099
09/19/13 10:26 PM
09/19/13 10:26 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Awesome and great progress. My Bee was one of the "ugly" 70 versions. Beige, 4 speed, ratty, scary fast, and the most fun I've had in a street car.
Old, tired, and sometimes broke down. Me, not my car...
[Re: Shoozy]
#1376100
09/20/13 06:34 AM
09/20/13 06:34 AM
OhioMopar
Mt.Gilead, Ohio
I had a Top Banana '70. I wouldn't call them ugly, really. That was before I knew much about working on/tuning anything. It was a 383 car with a 440 out of a Sea body in it and a pistol grip. Had lots of mud in it, but was painted with Glasurit, so it was really shiny!
[Re: OhioMopar]
#1376101
09/21/13 09:20 AM
09/21/13 09:20 AM
OhioMopar
Mt.Gilead, Ohio
Got it all put back together last night. Used the new Camaro hoses and everything back together. Didn't get to set the timing yet, but borrowed a timing light. I'll get it done this week.
[Re: OhioMopar]
#1376104
10/01/13 06:46 PM
10/01/13 06:46 PM
Shoozy
Southern by Choice
Oh so close gotta beat the snow!
[Re: 69_SIX_PACK]
#1376106
11/14/13 10:47 PM
11/14/13 10:47 PM
OhioMopar
Mt.Gilead, Ohio
Progress has been very slow. A snail is speedy by comparison. I had a move and also lost my garage, so I had to move the car, too. So I have done a little. I sealed the header bolts. One is pretty well stripped, and may require drilling out and some Heli-coil if it doesn't seal. I went to replace the water temperature sending unit, and it snapped off. So I will have to get some easy outs and get that out so I can replace it and fill the cooling system again. Other issues to address: the timing jumps around a LOT. probably need to take one of the MP springs out of the distributor and maybe put a stronger spring back in. Still need to set the timing. I need to find clips to retain the lever from the door handle to the door latch on the drivers side and get the lock cylinder put in so I can lock the doors. And open them. Plenty of stuff to do, but working one bug out at a time. Need to get the engine squared away first off. Also ran into a strange problem. After a wiring mishap, I got it restarted, but flooded the engine while figuring out the wiring problem. On restart, the oil pressure came up almost at a crawl. Which was odd because as soon as it fired, it buried the gauge. I changed the oil, and it came up better, but not like it did. So I'll grab a manual gauge and see what is up with that. If it doesn't come up, I'll probably go straight to panic. So progress is slow, but the persistence continues. My favorite picture so far^^ On the trailer headed for its new residence. It is nice walking out the door and seeing it! Would rather have a garage to work on it in, though! As soon as I get settled and get my storage unit organized, at least I will get it inside...
[Re: OhioMopar]
#1376108
12/04/13 01:13 AM
12/04/13 01:13 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Hats off to you Darin. What I love about this thread, and about your demeanor is to get the car running, driving, and stopping. Get the CAR back to life, enjoy, and don't worry about the $50,000 restoration. I'm on the same pathway with mine so I appreciate you sharing your story. Cheers.
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
[Re: WyleECoyote]
#1376109
12/04/13 11:57 PM
12/04/13 11:57 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Watch this space, I'm going to do the same thing as Darin, get my 69 R/T running and roadworthy this Spring just as she sits now, I might have a few of the bigger dents pulled out but that's about it. I just did the same thing to get my 37 on the road.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1376110
12/05/13 01:48 PM
12/05/13 01:48 PM
OhioMopar
Mt.Gilead, Ohio
Thanks guys. I had an R/T for 11 years and did everything to make it my way and most things twice. I never drove it. I've had my Bee less than a year and have driven it out of the garage a couple times. It ain't pretty, but it's mine and I'm on the verge of having lots of fun and going through a lot of tires with it! I've been dormant lately, but I'll be back on it as soon as I can. Stay tuned!
[Re: OhioMopar]
#1376111
12/06/13 02:24 PM
12/06/13 02:24 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
shiney paint is over rated. the way this fall has been going, I'll be in primer for a while. but I'll haver the car out having fun.
1981 Dodge D150 360 auto
