Re: Dodge Truck Fuel Sending Units 1973-1979
[Re: 76dodgeboy]
#1375675
01/26/13 12:21 AM
01/26/13 12:21 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
You might find a sending unit at a dealer if your VERY lucky. They have been NS1 for several years, but if your dealer will do a nation wide search you may find one. Also you may find one on eBay, they turn up from time to time. But you will pay dearly for it. If you cant rebuild yours, or if its not just a bad ground (common problem) as a last resort you can add an aftermarket one to the tank, but it will require you to use a hole saw, and add a hole to the top of the tank. Be sure to order the ford/mopar style to get the closest to correct ohms for the factory gauge. 73-10 ohm. http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=276/mode=prod/prd276.htmhttp://www.amazon.com/Jaz-Products-378-2...ASIN=B002RLCOD6For the tank, either a salvage yard, or local sale.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: dmnrr04]
#1375676
01/26/13 06:10 AM
01/26/13 06:10 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Does anyone know where to get replacement fuel tank sending units for Dodge trucks from 1973-1979 ? How about fuel tanks as well ?
Thanks, Rick
In the cab, or in the frame tank?
[Re: redraptor]
#1375684
01/28/13 09:08 PM
01/28/13 09:08 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
In the frame, under the frame, along the frame. What The Frank is everybody talking about? I thought it was a saddle tank.
It has many names like I do when my wife is mad at me lol
