Page 19 of 20 < 1 2 17 18 19 20 >
#1906715 - 09/05/15 01:35 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970]
ntstlgl1970 Offline
Loc: Sac, CA, USA
Originally Posted By ntstlgl1970
Darius has been struggling to get his car driving right, he is in the same car club as me. To my knowledge he is not running the NAG1 as a stand alone....
The NAG1 is the same as the mercedes transmission that they use in a bunch of different chassis with a different id - I think it's called a 722.6 or something like that.
Quick followup on the NAG1- I talked to Darius at Sac raceway last weekend and he finally got his trans sorted out, its not a stand alone controller though. Biggest problem is just chrysler not wanting to support these types of swaps by sharing data like GM and Ford do.
#1920423 - 09/27/15 12:37 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970]
Chris'sBarracuda Offline
Loc: Arizona
Cool video explaining the differences between the Apache and Hellcat heads.. thumbs
https://www.facebook.com/moparmusclemag/videos/10153679527602792/?fref=nf
Chris.. wave
www.B1heads.com "Back In Black"
#1920432 - 09/27/15 12:48 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: Chris'sBarracuda]
Just-a-dart Offline
Loc: Glendora Ca.
I had not seen that, thanks Chris
"Just a Bracket car dressed up like a streetcar"
#1921011 - 09/28/15 12:24 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: Street Monkies]
Moparmal Offline
Loc: Melbourne.....Oz-land
Originally Posted By Street Monkies
Roughly what is the cost to build one of these engines for drag race use? From low to high cost.
Depends on your HP target.
Buggest inhibitor is the crappy slugs, piston/valve clearance and rods - so with an unopened motor I dont think youd see much more than appx 520 fwhp NA with a 6.1' ported heads, cam, headers, tune and modded intake.
Edited by Moparmal (09/28/15 12:27 AM)
The Red Baron.
Now with. - SRT 6.1 HEMI, 218 @ .50
3650lbs , Dual quads!! - 11.7 @ 115.4
https://www.facebook.com/photo.php?fbid=...e=3&theater
#1921039 - 09/28/15 03:53 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: Just-a-dart]
Loc: Arizona
Welcome Don..
I just noticed that I didn't title it..
DONE.. up
Chris.. wave
#1933717 - 10/17/15 09:39 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
hudsonhornet7x Offline
Loc: Plumer, Pa
Question:
Does anyone know the chamber size for eagle heads as well as 6.1 heads?
Would one head offer an advantage over the other?
Thanks for any input.
XP29H8B198192
#1933826 - 10/17/15 02:05 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
72Swinger Offline
Loc: Nebraska
Eagle 65cc
6.1 73cc
Whichever ones you have use, or get Apaches.
Edited by 72Swinger (10/19/15 09:06 AM)
Mopar to the bone!!!
#1934643 - 10/19/15 12:13 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
Wailin D Offline
Loc: Southern Missouri
Looking for the part numbers for the 6.4 hemi factory replacement crate engine, 470 hp non-MDS, and the 6.1 hemi factory replacement crate engine. Any help with this would be greatly appreciated! Thank you!
#1939169 - 10/26/15 06:57 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
Triple Threat Offline
Loc: Renton Washington
If using a 6.4 apache head on an early 5.7 block what head gasket is needed? 5.7 bore is likely too small, will the 6.4 work? 6.1?
-Dustin
392" G3 Hemi
1.37, 6.17@111, 9.74@136.9
#1940174 - 10/28/15 04:57 AM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
gregsdart Offline
Loc: Frostbitefalls (Rocky&Bullwink...
I was told to use the gasket that matches the block. As far as bore goes, there must be an after market gasket that will work. Guys have bored the 5.7 to 4.00. According to a picture of Apache heads sitting on a 5.7 un bored block, the chambers on the Apache heads are small enough to work with a 4.00 bore gasket.
GREG
Educated at SHK U
Measure with yardstick
mark with chalk
cut with torch!
528 cubic inch alky injected 440-1 wedge, 3055 race weight.
8.779 at 153.16 mph. 1.289 60 ft. density altitude 1617 feet. Best 60 ft 1.24
#1940362 - 10/28/15 12:33 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
Cometic 5.7L gaskets are 4.100 bore, so should be good there.
-Dustin
392" G3 Hemi
#1941150 - 10/29/15 04:08 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
cudaman1969 Offline
Loc: fredericksburg,va
What head is on a 06 6.1 SRT8 engine?
#1941152 - 10/29/15 04:15 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
All 6.1's use the same head, its just known as the 6.1, no code name.
-Dustin
392" G3 Hemi
#1941156 - 10/29/15 04:18 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: cudaman1969]
WO23Coronet Offline
Loc: Canada
They're just called 6.1 heads, no fancy name for them, still a good head, flow #'s comparable to an Eagle head
#1941161 - 10/29/15 04:28 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: WO23Coronet]
cudaman1969 Offline
Do they have problems with seats popping out?
#1941207 - 10/29/15 05:43 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
WO23Coronet Offline
Loc: Canada
I don't think so, it's the early 5.7 heads that we're known to do that, and generally (but not always) only if they were heated/ran hot
#1941425 - 10/29/15 10:31 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: WO23Coronet]
cudaman1969 Offline
Think it was over reved and broke top of lifter. Looked in pushrod hole with bore scope, saw seat beat up
#2033959 - 03/18/16 04:25 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
72Swinger Offline
Loc: Nebraska
5.7 stroker about to hit the track soon.
https://www.youtube.com/watch?v=X6LmseKXLzI
#2034164 - 03/18/16 09:39 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
Loc: Plumer, Pa
Any specs on that? Is sounds great!
XP29H8B198192
#2034203 - 03/18/16 10:18 PM Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart]
72Swinger Offline
Loc: Nebraska
It is a BFNY build, IIRC Eagle heads, 12.1 and a decent cam.
25,699 Registered Members
196,741 Topics
70 A-Body 4-Spd Reverse Lockout Linkage ID/Confirmation
by floyd
22 minutes 38 seconds ago
A moment of silence...
by feets
Today at 01:47 PM
Tire fit question on 84 D150
by Hellda84
Today at 11:39 AM
Question about NHRA firewall rules
by moparjoe360.4
Today at 10:50 AM
