Re: TQ on fast idle for too long
[Re: dOc !]
#1368298
01/11/13 10:32 PM
01/11/13 10:32 PM
Posts: 2,782 USA
JoesMopar
USA
Iron intake ? .... flapper working in the exh man?
It was never there. When I bought the car it was already missing but it still worked fine until I removed the carb and put it back on.
I'll see if I can find if something is binding but I tried to put it back exactly the way it was.
[Re: JoesMopar]
#1368303
01/12/13 04:39 AM
01/12/13 04:39 AM
Posts: 2,782 USA
JoesMopar
USA
[Re: JoesMopar]
#1368305
01/12/13 11:17 AM
01/12/13 11:17 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
check the manifold choke system... spring and rod could get stuck inside assemby. BTW it can take very long! thats why on laters models got the electric assistant control ( this si for BB, SBs got the same without ballast ): http://www.ebay.com/itm/NOS-1974-76-most...44e&vxp=mtron a side note.... by the way you run the spark plug wires on driver side I guess you got the MP repro spark plug wire set. That's based on pre 72s setup... those are incorrect for 73 and lates B blocks this is the correct set: http://www.ebay.com/itm/360171097502?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649driver side wires are longer to reach the valve cover route. I got a set with that PN and prooved ( 3838000 is the PN on my 74 catalog ). Then from that, requested that lenght to customwires set ( firecore ) it looks you have a missed bracket thought, which bolts to the top front valve cover bolt. I can give you measures if need, ALTHOUGH now, firecore set should have the measures to make them under request. I emailed directy with Lindsay and Rick about that
[Re: 383man]
#1368310
01/13/13 02:17 PM
01/13/13 02:17 PM
NachoRT74
Valencia, España
Just an idea... I think should be enough to check the valley pan opening, remove the EGR valve and check through the passages for that, instead remove the full intake just for checking. and I know this is off topic, but preffer post in public just in case I'm wrong about your car wire brackets setup, but this is mine ( post 73 Big Block, in this case 74 Charger ):
[Re: NachoRT74]
#1368314
01/17/13 04:07 AM
01/17/13 04:07 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Nice job on the engine detail! What kind of car is it in? Looks like a late B-Body cop car!
I have also had problems with the electric assist on chokes. My old '73 Fury I couldnt get that one to heat up and I have had lots more with that problem.
You might take it out and check to see if its heating up with just the element and not manifold heat.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
