Any diesels with torque converting cycling?
#1364499
01/05/13 12:48 AM
01/05/13 12:48 AM
Posts: 18 Southern Indiana
WildCat
Southern Indiana
Got a 95 Dodge 2500 4x4 extended cab 8' bed with cummins and automatic trans
About 5 years ago it started to turn the OD/OFF switch on even though the button wasn't pushed. And occasionally the converter would unlock.
I was thinking the the TPS was the problem with converter. Took it in for service before making 2 long trips pulling my 24' enclosed trailer. He recommended rebuild and thought the TPS was ok.
@ 97,000 had trans rebuilt and billet converter installed.
After having it rebuilt the converter was still unlocking some. Trans guy changed TPS and all was good for a while.
Then on trip to Florida it was ok going down and almost back home it started again. Running 72 MPH it unlocked and locked, thought might be the brake switch, held foot under pedal no help. Slowed down to 68 MPH stayed locked in. Next trip to Florida ended up being only able to run 65 mph and stay locked in.
Trans guy then gave me a paper showing torque converter cycling and what they did to solve the problem.
So for the last 5 years I have been chasing this problem. It only does it when running on the interstate above 70 MPH. So since I don't drive it much find out when on vacation that what I didn't work.
2 new batteries, 2 new negative cables, rebuilt alternator, TPS bypass switch and my last attempt to be able to run over 70, installed a toggle switch to orange wire with black stripe to pin 54 on module to ground it as instructed from TST site.
Thought that would be the last attempt, but the trans temp light then came on after having it locked in for a while.
It does this without pulling a trailer, pulling my 24' and 12' enclosed trailer, so load on the truck makes no difference, speed is determining factor.
WHAT SHOULD I TRY NEXT?
Re: Any diesels with torque converting cycling?
[Re: WildCat]
#1364500
01/05/13 12:51 AM
01/05/13 12:51 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Any chance it could be an issue with the VSS sensor, or its plug in? Possibly the solenoid in the valve body?
I am just tossing some ideas out, I haven't had any first hand experience with anything newer than a 93.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: WildCat]
#1364507
01/05/13 09:09 PM
01/05/13 09:09 PM
Posts: 452 Coeur d Alene, Idaho
jimbob101
You sure can! I actually took the factory trans temp sensor out which is inline just coming out of the front tranny line going to the oil cooler, and put the aftermarket sensor (Napa, VDO). I run an electronic temp gauge, and running at highway speeds is about 155degrees. Temporarily, you have to jumper the trans temp sensor plug (paperclip etc) or just let it hang but plugged in. Otherwise, it wont kick into 4th. This spot is THE best place for the sensor, that fluid will be the hottest (and most accurate) coming out of that line, those aftermarket tranny pan sensor locations will not even show up on a gauge.
Mine is in a '92 cummins auto OD nonlockup but yours is pretty similar, but with lockup. Towing 7K up a hill just to see what heat I could make in OD, I got up to 180degrees and didnt get past that.
So what I did with the factory sensor is I teed it in right before it goes into the front trans cooler line. There is actually factory rubber hose for a stretch which makes it perfect spot to put it with barbed fittings. You'll have to extend your 2wires up to that spot from the tranny. I don't recommend cutting up your nice factory bent steel tranny lines, they are not cheap from Dodge if you can get them.
Here's a pic of the tee before I installed it. The '93older don't have a "hot trans temp" lite in the cab, when it gets too hot, it just kicks it out of 4th gear, and that lets ya know.. So the factory sensor is my "backup" and I just watch the gauge.. The way I see it, if you see that trans temp lite comes on, sometimes it may be too late. ATF thermal breakdown probably starts at 230degree up, if you'r running that high anyways, you are shortening your lifespan of that tranny a great deal. I wouldnt run over 200degrees if I could.
Make sense?
-Jimbo
[Re: WildCat]
#1364510
01/06/13 08:25 PM
01/06/13 08:25 PM
DaytonaTurbo
Manitoba, Canada
but What wire did you install noise suppressor?
The wire that goes from the TPS to the engine computer. Apparently the factory ran the TPS signal wire along side the alternator charge wire resulting in signal noise. The filter just splices into the line before the computer. Did that and replaced my battery connectors at the same time and my converter cycling problem has been gone ever since.
[Re: DaytonaTurbo]
#1364511
01/13/13 02:49 PM
01/13/13 02:49 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
I have seen the brake pedal switch unlock the converter at highway speeds as well. Took me forever to figure that one out...
Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
