Re: Weight difference between aluminum and cast iron intake
[Re: moparcanuk]
#1363719
01/03/13 12:47 PM
01/03/13 12:47 PM
Posts: 892 MA
steve70
MA
I'm not sure what the cast iron intake weighs but aluminum is roughly 1/3 that amount.
1970 Challenger T/A 4 speed
[Re: steve70]
#1363721
01/03/13 01:52 PM
01/03/13 01:52 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
I had a cast iron 6pk on my 69 RR , when I removed the intake the front end lifted up about a 1/2" .
[Re: JohnRR]
#1363722
01/03/13 02:29 PM
01/03/13 02:29 PM
Posts: 21,474 N.E. OHIO, USA
A12
N.E. OHIO, USA
only laughing because it sounds true
[Re: DPelletier]
#1363723
01/03/13 03:05 PM
01/03/13 03:05 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
I'm putting an aluminum 6 Pack intake on my car and was wondering what the weight difference is between that and the cast iron version.
some of us have been wondering that for quite a while; now you can weigh both and let us know!
I don't have a cast iron one otherwise I would.
[Re: moparcanuk]
#1363724
01/03/13 03:22 PM
01/03/13 03:22 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Darn. Well, weigh yours and post it and maybe someone will weigh their cast iron job. I should have, but it's bolted to the engine now.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: moparcanuk]
#1363726
01/03/13 07:40 PM
01/03/13 07:40 PM
Posts: 4,309 Prospect, PA
BSB67
Prospect, PA
Cast iron = 38.6 lb 6Pk Alum. = 22.2 Lb
However, if you are looking at overall weight savings, the three Holleys weigh considerbly more than an AFB/AVS, closing the weight difference gap.
[Re: BSB67]
#1363727
01/03/13 07:46 PM
01/03/13 07:46 PM
Posts: 4,696 North Central USA (MN-WI area)
MuscleMopars
I think he wants to know the weight difference between a cast iron 6 pack intake and an aluminum 6 pack intake. Both would have the 3 2bbl Holley carbs...
Thanks, Eric email eric@musclemopars.com 715-426-HEMI (Shop) 612-669-CARS (Cell and Texts)Go to my Moparts "Profile" to see my web site
[Re: MuscleMopars]
#1363728
01/04/13 12:18 AM
01/04/13 12:18 AM
BSB67
Prospect, PA
ooops, my bad
[Re: BSB67]
#1363729
01/04/13 06:29 PM
01/04/13 06:29 PM
moparcanuk
Orleans, Ontario
Weighed on my house scale as pictured, it weighs 42 lbs. If aluminum is .39 the weight of cast iron as stated above, then a similar equipped cast iron intake should weigh: 42 lbs ----- = 107 lbs. .39 Right?
[Re: moparcanuk]
#1363730
01/04/13 07:49 PM
01/04/13 07:49 PM
BSB67
Prospect, PA
Weighed on my house scales as pictured, it weighs 42 lbs.
Right?
No.
Mine weighs about 39.5 lbs intake and carbs and fuel line (w/o kick-down and throttle bracket)
So, using your 42 lbs:
22/.39 = 56 for cast iron intake.
Carbs, brackets and fuel line weight about 20 lbs.
about 75ish pounds total
[Re: moparcanuk]
#1363735
01/05/13 10:18 AM
01/05/13 10:18 AM
BSB67
Prospect, PA
Do you know that for a fact?
Nope, just made it up, 22.2 lbs
[Re: BSB67]
#1363736
01/05/13 11:27 AM
01/05/13 11:27 AM
moparcanuk
Orleans, Ontario
Then what's your point? I could also guess at the weight of a cast iron intake but I want the actual weight. If anyone has a cast iron intake with mounted carbs that can be weighed then that would be close. Doesn't anyone have a cast iron intake that can be weighed?
[Re: moparcanuk]
#1363737
01/05/13 12:59 PM
01/05/13 12:59 PM
JohnRR
U.S.S.A.
Didn't you see his post above giving the weight of the alum 6 pk manifold and a cast iron 4bbl ?
The cast iron setup with carbs does not weigh 107 is what he is saying.
I'm going to ask a real STUPID question ... why does it matter ? If the iron weighs only 10 lbs more are you going to trade the alum. one for an iron one ? The iron one is not correct for 69 ... if that matters ....
