Re: Milodon 31580 Road Race Pan Help
[Re: Beep Beep]
#1363579
01/06/13 06:59 AM
01/06/13 06:59 AM
Posts: 427 Sweden
Mopar Guy
Sweden
Thanks DarrenB, it looks like there is a lot of room. I will go ahead and order the pan. I see you used studs for the oil pan hardware. Is it easier to install the windage tray, gaskets and pan compared to using bolts? Is external oil system better than using the factory pick up system?
I would recomend you to use the std bolts for the pan becas of the tight fit of the pick up !
Realy great work you did on the pan Darren !!!!!!!!!!!!!
[Re: Beep Beep]
#1363582
01/06/13 12:02 PM
01/06/13 12:02 PM
Posts: 427 Sweden
Mopar Guy
Sweden
I hope the Milodon pickup for that pan will work on my 4.15 crank in my B block. I am currently using the factory pickup with the 6 quart hemi pan and it works great. DarrenB that setup on your pan looks amazing.
The Milodon pickup for that pan should clear fine thoe it is a strait tube but be shore to order the corekt one becas they also have the Hemi pickup for that pan ! If the std windage tray (none stroker) works in your engine right now the pickup will defenetly clear !!!!!!
[Re: Mopar Guy]
#1363583
01/06/13 12:31 PM
01/06/13 12:31 PM
Posts: 749 NY
Beep Beep
NY
I am going to order the milodon 18328 which is a 3/8 pickup. I may have to trim the windage tray because I am currently using the stroker tray.
[Re: Beep Beep]
#1363584
01/06/13 12:50 PM
01/06/13 12:50 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
why not use the 31581 pan that has the external pickup already? I am clearing a set of Headman Supercomps on a 4.5" stroke Hemi with an external line to the front of the block. I had Al Debevec modify a V8 Kmember to Hemi and everything clears ok with a stock pitman and idler. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 64MAX]
#1363587
01/07/13 05:02 PM
01/07/13 05:02 PM
64MAX
[Re: Beep Beep]
#1363590
12/27/14 04:44 PM
12/27/14 04:44 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I have this pan in 70 Challenger 512 in with 2 inch TTI's, not even close to any clearance issues. I recommend studs at rear main retainer. Everything else I use bolts,,,do not use ARP bolts,,,they are shorter than stock bolts(also their washers are almost like ball bearings) and are stainless(locktite does not work well) and will continually loosen. I use no sealer except very small amount at rear of pan around the retainer.
Proper torque is very important at 15 pounds. Unfortunately flimsy construction of RR pan, tightening to that torque will dimple the pan, leading to leaks. I suspect a primary reason that so many pans are slathered with silicone so as not to leak.
Makes for misery to use this stuff when you are next looking at removing pan.
This little fix that I threw together using 1/8th by 1 inch steel stock has worked very well to allow proper torquing. Perhaps a kit opportunity for some enterprising machinist.
What must I learn to be able to include multiple photos in a single posting.?
[Re: lewtot184]
#1363592
12/29/14 02:44 AM
12/29/14 02:44 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
Consider a front end alignment issue if the pan hits the c link. My car had the steering wheel off center a bit when i got it. Stock pan cleared fine at full lock. The 31580 hit on the right side like in the one set of pics here. Centered the wheel and all was good.
I want my fair share
[Re: SomeCarGuy]
#1363593
12/29/14 04:59 AM
12/29/14 04:59 AM
astjp2
Utah and Alaska
I would be checking for the internal steering box stops and where the pitman is indexed. I have 2 1/4" primaries on my headmans and it clears but I had to get everything right and I still may put fast ratio in and have to fight that problem at a later date. Tim
[Re: Wildjones]
#1363595
03/02/15 07:40 PM
03/02/15 07:40 PM
Posts: 3,916 usa
lewtot184
usa
Sorry to dig this up, but can anyone point me in the right direction for something to block off the oil temp sender bung? I'm not certain what the threads are, nor where to look for such a thing?
Thanks!
1/2" pipe plug.
