Re: header kit or parts
[Re: Clanton]
#1356929
12/24/12 03:50 AM
12/24/12 03:50 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Depends on how much you want to spend and how nice you want it to look. I bought a header kit from Jegs and a few extra j bends from summit. You can also buy weld rings so the welds don't protude into the tube when you butt weld. When i decided I needed two tube around the frame I bought cheap slip on collectors from summit. I used steel tubes and mig welded them. Looks like crap on the outside, looks fine on the inside. https://board.moparts.org/ubbthreads/show...rue#Post7358657
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: earthmover]
#1356930
12/24/12 01:37 PM
12/24/12 01:37 PM
Posts: 4,488 northern,Ohio,USA
Clanton
northern,Ohio,USA
----------------------------- 2 step style 1st pri dia... 2.050" ... length .. 16.7" to 18.3" 2nd pri dia... 2.175" ... length .. 16.7" to 18.3" coll. size 3.725" to 3.975" .. length 17.9" -----------------------------
this is the header I plan to build for my race car .. what are you guys doing for the bends and flanges??? buying kits and make them work how you like or just buy a lot of diff. bends and so on???who has the best price on this kinda stuff??? I have seen where guys buy big block chevy kits and use them with the mopar flange cut weld cut weld..lol
I wonder how well those sizes will fit togather,I have a pipe expander that I may use to make some slip joints.Have A very Merry Christmas ALL of you!
[Re: earthmover]
#1356932
12/24/12 04:39 PM
12/24/12 04:39 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
It should all slip together. I always purge the tubes also, best way to get a good looking and strong weld on the tubes.
One day I will have something cool here.
[Re: earthmover]
#1356935
12/24/12 10:05 PM
12/24/12 10:05 PM
Posts: 2,449 nc
earthmover
nc
single primary style header pri dia... 2.050" to 2.175" ...length 33.5" to 36.6" collector dia... 3.725" to 3.975" .. length 17.9" ----------------------------- 2 step style 1st pri dia... 2.050" ... length .. 16.7" to 18.3" 2nd pri dia... 2.175" ... length .. 16.7" to 18.3" same collector -------------------------------- 3 step style 1st pri dia... 2.050" ... length ..16.7" to 18.3" 2nd pri dia... 2.175" ... length ..8.4" to 9.1" 3rd pri dia... 2.300" ... length .. 8.4" to 9.1" same collector but stay to the large size all specs are OD with a wall thickness of .062 this is what the program came up with ,and my choices to go by...I was thinking the step would make the most power..and I need all I can get..lol
[Re: earthmover]
#1356936
12/24/12 11:02 PM
12/24/12 11:02 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
It's all up to the amount of room you have. That's the main factor My car being stock with T bars and stuff it's all a trade off. I just went big and unequal lengths. 2&1/4 with short and longs lol. It's hard get the fronts short with stock shocktowers. These were what put my car in the fives in the 1/8. I had hooker fenderwell supercomps and it would run hi O's. Only thing changed were headers and it went low .90's
[Re: earthmover]
#1356942
12/25/12 04:10 AM
12/25/12 04:10 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
they will be on a chassis car with strut frontend..only thing really there is the master cylinder and brake stuff is mounted in the floor...ill take some good shots of the front and the room I have .. the pass. side is open just the driver has the normal.....
Get a Hedman BB MoPar kit or SBC kit and flanges from anybody for the least expensive option. Step headers require a little more thought , but you have enough room to do anything you want header wise.
