Page 3 of 4 1 2 3 4
Re: Is a 6 Pack worth the money and trouble? [Re: 62maxwgn] #1356652
12/23/12 02:27 AM
12/23/12 02:27 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
When I used to race my A12 Runner in the early 70's, it had over 13:1, big valves, a .626 lift cam, 4.88's, etc. I tried switching to an Edelbrock TM7 Tarantula intake, a 2" spacer and a Holley 850 DP for a while. It ran the same times and speed but did not get the hole shot my 6BBLs got...and just didn't have the same wow factor to me.
Re: Is a 6 Pack worth the money and trouble? [Re: 2boltmain] #1356653
12/23/12 12:12 PM
12/23/12 12:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
haven't tried these yet but should be a simple, easy to tune alternative to a 6bbl.
Edelbrock 2x4 setup is less expensive than a 6 pack.
Yeah but it comes w/ 2 edelbrock carbs
Coming soon!!!!
Re: Is a 6 Pack worth the money and trouble? [Re: Mr.Yuck] #1356654
12/23/12 12:13 PM
12/23/12 12:13 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
That's a good thing! I'll take any you want to toss out ;-)
Re: Is a 6 Pack worth the money and trouble? [Re: Mr.Yuck] #1356655
12/23/12 01:01 PM
12/23/12 01:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
now, now! there's nothing wrong with afb's, .
Re: Is a 6 Pack worth the money and trouble? [Re: gdonovan] #1356656
12/23/12 01:58 PM
12/23/12 01:58 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Too late gave mine to a chebbie guy.
Decided to try one years ago, bought a shiny new 1407 Edelbrock carb for my 440 4 speed Challenger replacing the strong running (but a little dirty looking) Holley 750dp carb it had on it.
The Edlbrock had a terrible stumble off idle and no where near the performance of the Holley.
Bought the Edelbrock tuning kit and spent hours trying to tune it.
Called Edelbrock tech line countless times, They had me doing all kinds of stuff including drilling out emulsion tubes, some improvement but the stumble never went completely away and still no where near the performance of the Holley.
The techs at Edelbrock were nice and helpful and even sent me parts to try for free but in the end they finally admitted these type carbs where NOT designed for performance big block Mopars...more for stock small block chebbies.
Pulled the Edelbrock carb (gave to a chebbie buddy) and replaced with the old Holley and the car ran perfect(and fast) again.
Still got the Edelbrock tuning kit somewhere.
Live and learn.
Re: Is a 6 Pack worth the money and trouble? [Re: KillerBee] #1356657
12/23/12 02:34 PM
12/23/12 02:34 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
That is a ridiculous statement from the Edelbrock employee as a carburetor doesn't have a clue as to what is pulling a vacuum under it. Something was wrong with your carb, pure and simple.
I could give you a ride in my GTX as it will explosively break the tires loose by merely stabbing the gas pedal.
With either the 750 AFB (now on my Duster) I use to run, or the 900 CFM Thermoquad that is currently on it.
A great book to read about how Carters work-
http://www.amazon.com/Carter-Carburetors...rter+carburetor
Re: Is a 6 Pack worth the money and trouble? [Re: gdonovan] #1356658
12/23/12 03:21 PM
12/23/12 03:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's my take. If you want the ultimate "Wow" factor yank the 408 and drop in a GenII Hemi. Done!
IMO it's hard to beat an STR12 for a small block in terms of under hood glamor (EXPENSIVE!), but they can be a trial to find, install, and tune properly.
If you want the car to perform to it's limit you'll likely find the best way to get there is a single 4 barrel.
For vintage look I'd go with a Thermo-Quad, you don't need a Comp series unit either (they work great but are not very street friendly). For a more modern approach it's hard to beat a Holley 950 on a stroker small block with an aggressive cam profile.
Six packs are great dependable power makers as well (and if properly tuned) will perform with nearly anything, but it's a lot of extra expense and hardware to get to the same goal a 4 barrel can reach, plus, if you run a stock oval air cleaner a 4 barrel looks basically the same as a Six Barrel when all covered up, all that money and now it's all hidden, that goes double if you run a Shaker hood.
Dual 4's are sort of the same story, not really needed but if you like the look and don't mind the added expense you won't likely lose (unless you over carb the engine) or gain any performance over a well chosen single 4 setup.
Re: Is a 6 Pack worth the money and trouble? [Re: 95Kota408] #1356659
12/23/12 09:57 PM
12/23/12 09:57 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
No
Re: Is a 6 Pack worth the money and trouble? [Re: pishta] #1356660
12/24/12 05:55 AM
12/24/12 05:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Are paper 6 pack filters being reproed again or are nos ones still listing for 350 bucks?
Re: Is a 6 Pack worth the money and trouble? [Re: DaytonaTurbo] #1356661
12/24/12 12:33 PM
12/24/12 12:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If you are talking about the orange round hole original style, no, not to my knowledge, athough they likely will make more eventually. And BTW, the $350.00 examples you commonly see offered are not typically NOS, they are remaining Fram reproductions, NOS (New OLD Stock from the early 70's) usually go for more than that.
Re: Is a 6 Pack worth the money and trouble? [Re: ScottSmith_Harms] #1356662
12/24/12 12:55 PM
12/24/12 12:55 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
...and K&N has a nice filter that will outlast all of us.
Re: Is a 6 Pack worth the money and trouble? [Re: jbc426] #1356663
12/24/12 01:26 PM
12/24/12 01:26 PM
Warner Robins, Georgia
DusterMan Offline
super street
DusterMan  Offline
super street
The mechanical six pack Holley 2300 carbs were sold over the counter under the Direct Connection banner as "Racing" carbs. They were also used on Ford's during the '60's. It takes a bit of searching, but there are still a lot of nice sets out there, especially if you Google Ford set-ups.
Those carbs were 500 cc 2 bbl's with accelerator pumps. That is all I ran on 6pk setup in the late 70's and early 80's.
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: Is a 6 Pack worth the money and trouble? [Re: DusterMan] #1356664
12/24/12 01:29 PM
12/24/12 01:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How do you make the Ford carbs fit a Mopar manifold?
Re: Is a 6 Pack worth the money and trouble? [Re: lewtot184] #1356665
12/24/12 02:41 PM
12/24/12 02:41 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
you will love the 6pak,especially the kick in of the outboards! i love mine and wouldn't do it any different.
Re: Is a 6 Pack worth the money and trouble? [Re: 1_WILD_RT] #1356666
12/24/12 04:04 PM
12/24/12 04:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the mechanical end carbs were the same size throttle bores and venturi as the factory vacuums, definitely not the 500cfm aftermarket carbs. the ford carbs will bolt up but they were very small, like the mopar and chevy center carbs.
Re: Is a 6 Pack worth the money and trouble? [Re: lewtot184] #1356667
12/24/12 04:09 PM
12/24/12 04:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Actually since the Ford carbs all have metering blocks the rear carb won't fit... The center carb always has a metering block so that's not an issue & the front carb just protrudes an extra 3/4" but the rear carb will not fit....
Re: Is a 6 Pack worth the money and trouble? [Re: gdonovan] #1356668
12/24/12 05:13 PM
12/24/12 05:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Is that 750 AFB a real Carter AFB, or an Edelbrock/Carter/Weber/ Abortion Four Barrel AFB?
Re: Is a 6 Pack worth the money and trouble? [Re: 1_WILD_RT] #1356669
12/24/12 06:27 PM
12/24/12 06:27 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the ford carbs will bolt up because they use side pivot bowls; the same as 6-pak mechanicals.
Re: Is a 6 Pack worth the money and trouble? [Re: lewtot184] #1356670
12/24/12 06:52 PM
12/24/12 06:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Oh yeah.. Last Ford Tri-Power I played with was in the 70's.. I clearly remembered the metering plates.. Completely forgot the side pivot bowls...
Re: Is a 6 Pack worth the money and trouble? [Re: 1_WILD_RT] #1356671
12/24/12 06:56 PM
12/24/12 06:56 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i love it on my 340, but that air cleaner covers it all up when you open the hood..if you notice the pictures shown... some with and some with out...people notice when its out...well at least to those non mopar people...
Page 3 of 4 1 2 3 4
