Re: How to Paint Steel Weels [Re: SANDYinNS Canada] #1351597
12/16/12 04:18 PM
12/16/12 04:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He's starting with Bare rims.
Re: How to Paint Steel Weels [Re: 76dodgeboy] #1351598
12/16/12 04:49 PM
12/16/12 04:49 PM
Sac, CA
mopowers Online confused OP
mopowers  Online Confused OP
Sac, CA
Yeah, I''m starting with bare rims, so I'm not sure mounting a set of tires prior to painting will be a advantageous. Thanks for the all the ideas guys. I appreciate it. I mainly just wanted some verification that it'll be okay to use an aerosol primer/sealer under the gunned on acrylic enamel. Any ideas what brands are best for the aerosol primer/dealers??? Duplicolor, Rustoleum, etc...
Re: How to Paint Steel Weels [Re: mopowers] #1351599
12/17/12 11:13 PM
12/17/12 11:13 PM
IN
ahy Offline
ahy  Offline
IN
Rustoleum auto prmer, etc...
Has worked well for me under automotive top coat.
Re: How to Paint Steel Weels [Re: ahy] #1351600
12/18/12 03:22 PM
12/18/12 03:22 PM
dogdays Offline
dogdays  Offline
Sand off the rust and scuff any paint well. Be ready to prime IMMEDIATELY.
Shoot on a coat of automotive etching primer. If you want to spend the time, lightly sand to get a smooth surface. You may have to shoot and sand again if you get carried away.
Spray with the automotive paint of your choice.
Enjoy!
R.
Re: How to Paint Steel Weels [Re: mopowers] #1351601
12/19/12 12:32 AM
12/19/12 12:32 AM
I just used a HF abrasive blast gun #92857 $24.95 and bought 5 lbs of #98329 glass beads today & tried it out this evening & it cleans so fast I was totally impressed. I had a quantity of some unlabeled dark red fine abrasive which didn't come from HF which didn't work so I tried the glass beads on a spot on a junk rim as I was leery just to see if it'd work as I thought maybe the HF gun was for some special media & it sure did work like gangbusters. Waiting for a warm(er) day so I can finish blasting then etch/prime then paint with the recommendations in this thread EDIT the glass beads were $7.99
Re: How to Paint Steel Weels [Re: RapidRobert] #1351602
12/19/12 04:16 AM
12/19/12 04:16 AM
Sac, CA
Sac, CA
How long did it take to do the rim??? And how much bead did you go through???
Re: How to Paint Steel Weels [Re: mopowers] #1351603
12/19/12 12:08 PM
12/19/12 12:08 PM
My rims are in my mini shop/garage & I was over at my buddys shop as he has a massive air compressor so I grabbed a junk rim & did a small spot just enough to see where I was at with this. It cut very fast so I THINK I'll easily have enough to do my 4 rims on the front side. I am going to spread a big tarp out to catch everything & recyle em if need be especially if I am very close to being finished to avoid another trip to HF. With my limited experience with blasting/painting I'm just happy that this went very well especially after the first media I used didn't do squat. Not sure what psi our compressor runs at but it is substantial & I'm sure that makes a difference. From what I've experienced so far these rims will be prepped in a matter of a few minutes
Re: How to Paint Steel Weels [Re: RapidRobert] #1351604
12/19/12 07:55 PM
12/19/12 07:55 PM
dulcich Offline
dulcich  Offline
Robert, I don't think you can get very far with only 5-lbs of glass bead. I would expect to use 50-lbs of media per wheel to really clean them up.
-dulcich
Re: How to Paint Steel Weels [Re: dulcich] #1351605
12/19/12 10:04 PM
12/19/12 10:04 PM
Hello Steve, Alright I will spread the tarp
Re: How to Paint Steel Weels [Re: mopowers] #1351606
12/19/12 10:10 PM
12/19/12 10:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Had these powder coated.
