Anyone ever make these???
#1349166
12/10/12 04:15 PM
12/10/12 04:15 PM
Posts: 3,009 Sac, CA
mopowers
Sac, CA
I'm thinking I may need to do the 3/4" offset thing on my Dart to get the tire I want under it. I've got a bunch of regular shackles laying round and nothing but time. These seem like they'd be a breeze to make up by cutting up some shackles where the bushings are, offsetting them, and connecting the dots by welding in some new steel. Has anyone ever done this??? The only reason I'm considering it is because I already have poly bushings and quite a few shackles laying around. Doesn't seem worth the $90 they want for a pair.
Re: Anyone ever make these???
[Re: mopowers]
#1349169
12/10/12 06:36 PM
12/10/12 06:36 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
But... As you've probably noticed, teh factory shackles have a mild bowl where the bushing seats. However, the aftermarket polyurethane shackle bushigns tend to be flat-faced (but I'm sure they mush as needed). My original beef was the welding aspect. What about getting some 1/4" flat and bending the metal to the correct shape, then drilling for new bolts? would work well with poly bushings adn 9/16" dia bolts. Teh cost is adding up, though.
[Re: Fury Fan]
#1349170
12/10/12 07:09 PM
12/10/12 07:09 PM
mopowers
Sac, CA
I see your concern. I was looking at the front offset hangers and they are welded. I always thought a weld (properly done) is stronger than the parent metal??? That's a decent idea about finding some 1/4 stock and bending it though. I wonder how hard it would be to bend a 1/4" strap with a bench vice?? I don't have an oxy/acc set-up. Just map gas...
