Page 1 of 3 1 2 3
w8 head studs #1348930
12/10/12 01:29 AM
12/10/12 01:29 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
my ritter block uses 1\2 in studs. my w8 heads have 4 smaller 3/8 holes 2 in each head so im looking for a step stud. dose any body know where to find something like that 1/2 to 3/8
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: w8 head studs [Re: WHITEDART] #1348931
12/10/12 01:57 AM
12/10/12 01:57 AM
Out West
408strokerdart Offline
Out West
ARP. And be prepared to bend over.....all the way for the good ones.
You will probably have to call them for these. I don't remember seeing them in the catalog.
Re: w8 head studs [Re: 408strokerdart] #1348932
12/10/12 10:28 AM
12/10/12 10:28 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Yerp. Might want to call Ritter. He may have a set somewhere. Otherwise you are looking at well over $500 maybe over $1,000 now. Those things are like gold.
Re: w8 head studs [Re: WHITEDART] #1348933
12/10/12 11:17 AM
12/10/12 11:17 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I believe Ritter has em,,,,there about 115 a piece
Re: w8 head studs [Re: fishy340] #1348934
12/10/12 08:34 PM
12/10/12 08:34 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
OK $2,250 for the 20 studs. Or is that $115 for the long studs on the top row?
Re: w8 head studs [Re: Leon441] #1348935
12/10/12 09:47 PM
12/10/12 09:47 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
We just found out that Ritter buys them in bulk to fit all the different W-8 combos. You will save big money over going threw ARP direct. If you can even get them to return you call.
Re: w8 head studs [Re: Leon441] #1348936
12/10/12 10:04 PM
12/10/12 10:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
2 per head...4 total
Re: w8 head studs [Re: Leon441] #1348937
12/10/12 10:06 PM
12/10/12 10:06 PM
bean town ....Ca
W
W
bean town ....Ca
the ones I need is the four long ones that goes in between the intake runners
Re: w8 head studs [Re: WHITEDART] #1348938
12/10/12 10:31 PM
12/10/12 10:31 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I went through arp but all my studs are 1/2to3/8 and i had $980 bucks in them.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: w8 head studs [Re: bdaz smblk] #1348939
12/10/12 10:38 PM
12/10/12 10:38 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Can you check for me but I thought yours should be 1/2 to 7/16 that's what the last w8 PST stuff was from CFE.
Re: w8 head studs [Re: W5DART66] #1348940
12/10/12 10:58 PM
12/10/12 10:58 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Your rite mine is 7/16 except the 8 3/8 studs
Re: w8 head studs [Re: bdaz smblk] #1348941
12/10/12 11:05 PM
12/10/12 11:05 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My set from Patterson were 1/2" to 7/16" 5 long and 5 short for each head. The CFE heads were drilled for 7/16.
I let my studs go with the heads. Didn't realize until I was well on my way I was not paid for the studs. That's what you get counting money in a thunder storm. The part that sucks is I was practically giving them away to start with.
Now listening to the prices of these studs. I really got screwed.
Leon
Re: w8 head studs [Re: WHITEDART] #1348942
12/13/12 05:39 PM
12/13/12 05:39 PM
bean town ....Ca
W
W
bean town ....Ca
I found a thearded insert that I can put in the block that cost about 2 bucks each.. the outside theard is 1\2 13.. inside theard is 3/8 16.. I hope this will work.. has any body tried this
Re: w8 head studs [Re: WHITEDART] #1348943
12/13/12 08:26 PM
12/13/12 08:26 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
3/8 studs will not torque tight enough. These heads use 7/16.
Can't remember the exact torque but you go 85 lbs with stock 1/2" bolts. You can go a little more with 1/2" studs. 7/16 stepped studs went around 80 lbs. A 3/8 was only around 60 lbs.
10 head bolts at 85 lbs was not enough. Now you want to go with 18 3/8 head bolts. Would not recommend that.
Re: w8 head studs [Re: Leon441] #1348944
12/13/12 08:48 PM
12/13/12 08:48 PM
bean town ....Ca
W
W
bean town ....Ca
it would only be the 2 in each head the others 16 will be 1/2 inch .. it is the 2 that are in between the intake runner
Re: w8 head studs [Re: Leon441] #1348945
12/13/12 09:23 PM
12/13/12 09:23 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
they will be fine that is how all the good W8 castings are...
I will post pictures of the step stud and better casting W8s.
Re: w8 head studs [Re: W5DART66] #1348946
12/16/12 03:53 PM
12/16/12 03:53 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Sorry I forgot about this post.
But here is picture of w8s that had small 3/8 head studs just in the head bolt holes that are in the intake ports.
Re: w8 head studs [Re: W5DART66] #1348947
12/16/12 04:01 PM
12/16/12 04:01 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
And here is the stud arp made for this application.
Re: w8 head studs [Re: W5DART66] #1348948
12/16/12 06:16 PM
12/16/12 06:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Bret that appears to be a 1/2" stepped to 7/16". Are you saying this is a 1/2" stepped to 3/8". If that were the case you would not need to high dollar studs just thread reducers in the block like the OP suggested.
Re: w8 head studs [Re: Leon441] #1348949
12/16/12 07:10 PM
12/16/12 07:10 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
It's 1/2 to 3/8 I will set 7/16 by it so you can see.
Page 1 of 3 1 2 3
