Ford vs mopar steelie??? #1345991
12/04/12 05:24 PM
12/04/12 05:24 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is there an easy way to tell a Ford vs a Mopar steel wheel??? Do they both have the same hub size?? Hubcap size???
Re: Ford vs mopar steelie??? [Re: mopowers] #1345992
12/04/12 05:36 PM
12/04/12 05:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have seen Ford stamp their wheels with the ford logo and the hub is smaller on a ford but not by much.
Re: Ford vs mopar steelie??? [Re: stumpy] #1345993
12/04/12 05:38 PM
12/04/12 05:38 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Ford stamps their wheels with the ford logo and the hub is smaller on a ford but not by much.
Thanks! So now I just need to find out how big the hub is for a mopar rotor. I found a couple wheels but I'm suspecting they may be ford. Do they use the same size hub cap??
Re: Ford vs mopar steelie??? [Re: mopowers] #1345994
12/04/12 05:48 PM
12/04/12 05:48 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I don't believe so but not 100% easiest way to know is try a hubcap before you buy them
Re: Ford vs mopar steelie??? [Re: 76dodgeboy] #1345995
12/04/12 05:53 PM
12/04/12 05:53 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Yeah, that's the way to go, but a nice guy at a tire shop gave me these wheels for free. So no harm no foul.
Re: Ford vs mopar steelie??? [Re: mopowers] #1345996
12/04/12 06:02 PM
12/04/12 06:02 PM
Andrewh Offline
Andrewh  Offline
maybe I am thinking wrong, but isn't the center your problem?
ford's are smaller, so it won't sit flush when you try to bolt them up?
I remember seeing one where someone cut out the center so he could bolt up the ford wheels to his RR a long time back.
Re: Ford vs mopar steelie??? [Re: Andrewh] #1345997
12/04/12 06:06 PM
12/04/12 06:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& FoMoCo used the 10" hub caps at least thru the '70s
Re: Ford vs mopar steelie??? [Re: 6bblgt] #1345998
12/04/12 06:15 PM
12/04/12 06:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
a typical '68-'69 14x5.5" Mopar wheel
Re: Ford vs mopar steelie??? [Re: 6bblgt] #1345999
12/04/12 06:17 PM
12/04/12 06:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
a typical early '70s 14x6.0" FoMoCo wheel
Re: Ford vs mopar steelie??? [Re: mopowers] #1346000
12/04/12 07:02 PM
12/04/12 07:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can open the center of a ford rim a little with a dremel and make them fit Mopar. Don't know about hubcap fit.
Re: Ford vs mopar steelie??? [Re: stumpy] #1346001
12/04/12 07:52 PM
12/04/12 07:52 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ford rims on the 67.
Re: Ford vs mopar steelie??? [Re: BSB67] #1346002
12/04/12 08:03 PM
12/04/12 08:03 PM
dogdays Offline
dogdays  Offline
The 16 x 7 1998 - 2002-ish Ford cop wheels are really nice. The center needs a bit of opening but it isn't much. I don't know about caps, I don't run them.
R.
Re: Ford vs mopar steelie??? [Re: 6bblgt] #1346003
12/05/12 01:15 AM
12/05/12 01:15 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Thats the big difference and problem I've noticed.
The center register size can be opened up to fit with a dremel or light filing. I've done it before, not much of a difference really.
