Z Bar ID...Whats correct for E-Body #1343576
11/30/12 06:15 PM
11/30/12 06:15 PM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
Does anyone have correct diemensions for the E body Big Block Z Bar. I have a bunch of Z bars but cannot tell whats from what anymore. I am looking to find one that will fit my 70 challenger 440 4 speed.
Thanks,
Steve
Re: Z Bar ID...Whats correct for E-Body [Re: HemiChallenger] #1343577
12/03/12 05:26 AM
12/03/12 05:26 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I don't have one to take measurements from for you, but I've had good luck identifying parts using the pictures and descriptions on the Brewers website.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: Z Bar ID...Whats correct for E-Body [Re: Evil Monkey] #1343578
12/03/12 10:45 AM
12/03/12 10:45 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Just played this game with a 440 Sixpack install in my 1971 R/T Challenger.
First, you need to determine what size bellhousing you have, 10 1/2" or 11".
The tube length is 9", the difference in the torque shafts is how close the offset arm is welded to the end of the tube.
That determines what adjusting rod you use also.
E-body info at the bottom of the page.
http://www.brewersperformance.com/products.asp?cat=105
Re: Z Bar ID...Whats correct for E-Body [Re: KillerBee] #1343579
12/03/12 10:58 AM
12/03/12 10:58 AM
Millersville, PA
Millersville, PA
thanks guys
